Is this the right Capacitor?
drselect
drselect Posts: 664
edited June 2010 in DIY, Mods & Tweaks
I am working on the 4.1TL mod to my SDA CRS+ and was wondering if I ordered the right capacitors from Sonic Craft? In reviewing the other posts on the 4.1TL mod I have not seen the capacitors used have the "Gen I" labeled on the capacitor. I did specify the Gen I capacitor but now after rereading F1nut thread (http://www.polkaudio.com/forums/showthread.php?t=40577) on his 4.1 TL mod I am not sure if I should have gotten the "Gen I" or "Gen II". I have attached pictures of the capacitor I received and of my XO.
Post edited by drselect on
  • Face
    Face Posts: 14,340
    edited June 2010
    Gen II are only available in small values, generally for electronics.
  • fbm211
    fbm211 Posts: 1,488
    edited June 2010
    Those caps are correct.I have the same ones.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • drselect
    drselect Posts: 664
    edited June 2010
    Thanks for the reply Face and fbm211
