Full set of Polk LS on eBay
schaesc
Right now eBay has several Polk LS speakers for sale. There is an auction for a good looking pair of LS-90, a CS-350LS, and then a pair of white LS f/x speakers. All look like they are in great condition.
I have been looking for a 3rd PSW 300, but little luck finding one . . .
Post edited by schaesc on
Not mean to sound rude, but if you need 3 of the same sub, don't you have to think that the thing isn't what you're looking for in A sub? With the money that you're tying up in that thing, you could have a significant improvement in the bass department.comment comment comment comment. bitchy.
well actually more than one sub actually helps dealing with room resonance (peaks and nulls) and in some cases, 4 cheapo subs sound better than one expensive sub (which is a hint to my new project).
Personally, I'd look at placement options on the ONE sub before I'd go out looking to get a sub for every P&N that I had in the room. Why would one want that many seperate boxes floating around and cluttering up the space........
bygones.......comment comment comment comment. bitchy. -
bygones.......
Why not?Vinyl, the final frontier...
I agree with max, having a sub in each corner or one in each of two corners looks cool to me...Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
Sorry, should have explained that the 3rd sub is for a different room.
I have a pair of RT16s, each with a flanking PSW 300, a CS 350LS, and two sets of white LS f/x for side and rear surround. I call it my "poor man's" SRT system. -
I run 1.2s in the front and 2.3s in the rear. For a while I didn't have any sub as I thought that the 4 15s in the corners would be sufficient. What I discovered was especially on movies I wound up with a bunch of standing waves with the LFE information coming from all 4 corners. I added a small Shure 12 inch sub, powered it with a Mac 250 bridged to mono and routed the LFE information to it. This cleaned up the sound a bunch.
Phil
