Any recommendations on a cheap DAC?
giant016
giant016 Posts: 10
Most of my music is on my laptop and it is an older cheap Inspiron that has a pretty terrible soundcard. I don't need anything fancy. I'm just looking to bypass my soundcard accurately. Portability is not an issue. Unless there is some amazing one out there I'd like to keep it under $100 (actually under $50). I was looking and the Phillips Aurilium and the Fireye I/II. Unfortunately the Phillips is pretty hard to find new now for a decent price and the Fireyes have problems at low volumes which is primarily what I would use it for. Any suggestions?
  • Face
    Face Posts: 14,340
    edited June 2010
  • John K.
    John K. Posts: 822
    edited June 2010
    G16, for an item which does what you want at reasonable cost, consider this .
  • dorokusai
    dorokusai Posts: 25,661
    edited June 2010
    I've been very happy with the Music Streamer+ that I use now.
  • giant016
    giant016 Posts: 10
    edited June 2010
    Hmmm.... Some choices. I fail to see the difference between the $20 and $220 units. Likely higher end metals for connections, but aren't these pretty simple devices? I thought the idea was to deliver unchanged audio (well, convert it).
  • Face
    Face Posts: 14,340
    edited June 2010
    A $20 DAC will probably be on par with your current sound card.
  • giant016
    giant016 Posts: 10
    edited June 2010
    Are not that many people running audio from their computers? There doesn't seem to be any mainstream products for USB DAC. I know that most would prefer other audio sources, but it's just so damned convenient.
  • Face
    Face Posts: 14,340
    edited June 2010
    There are many USB DAC's out there, but most are above your price point.
