Anyone know the Capacitor uF value for the tweeter in a CS400?
headrott
headrott Posts: 5,496
edited June 2010 in Speakers
I need to know the capacitor value (uF and voltage) for the tweeter in a CS400. If anyone knows it or has a schematic for this center channel can you post a link for it, or just let me know what value it is? Thanks for everyones' help.
Greg
Post edited by headrott on
  • Face
    Face Posts: 14,340
    edited June 2010
  • headrott
    edited June 2010
    Awesome! Thanks very much Face! I did a search, but didn't find this link. I must have simply missed it. Thanks for the help!
    Greg
  • FTGV
    FTGV Posts: 3,650
    edited June 2010
    12uf 100volt.
    Edit.ooops too slow.
  • headrott
    edited June 2010
    OK, another question. Do you think it would be OK to put a 10uF capacitor in for the 12uF capacitor? The 10uF has a +/- 5% tolerance to it. It is a Sonicap. So do you think it would be too much outside the tolerance to work correctly? Any help appreciated.
    Greg
  • rooftop59
    rooftop59 Posts: 8,120
    edited June 2010
    not to derail the post, but does anyone (face?) have a schematic for the cs400/400i midbass drivers?
    Thanks,
    Paul
    Game Room 5.1.4:
    Bedroom 2.1
  • FTGV
    FTGV Posts: 3,650
    edited June 2010
    headrott wrote: »
    Greg
    That would shift the tweeters crossover point up slightly,the likely result being a small dip in response at the crossover.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2010
    Don't forget, that if you switch that cap out you'll need to give it plenty of time for it to burn in before you can really enjoy it again.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • rooftop59
    edited June 2010
    rooftop59 wrote: »
    Thanks,
    Paul
    oops...didn't notice at first that the schematic includes all the drivers;)
    Game Room 5.1.4:
    Bedroom 2.1
  • Conradicles
    Conradicles Posts: 6,405
    edited June 2010
    One more derail...can anybody supply the schematic or values for a CS300?
    Thanks!!!
  • Face
    Face Posts: 14,340
    edited June 2010
    It's not too difficult to pull the x-over and make heads and tails of what's inside. Polk uses mostly simple slopes, so there should only be 1-3 parts per driver.
