Do I Need Replace Center Channel Speaker?
Kage
Kage Posts: 3
edited June 2010 in Speakers
I have a 3.1 channel setup and I recently bought the TSi300 floorstanding speakers to replace my left and right channel bookshelf speakers. I also have the Polk Audio DSW Pro 400 sub and the Polk Audio CSi30 center speaker. I'm wondering if I have a good setup or do I have to replace the center channel speaker to match with the TSi300's? If I have to replace the center speaker which one do you recommend?
Post edited by Kage on
  • Ric5811
    Ric5811 Posts: 400
    edited June 2010
    If you want to replace, the CS 10 is matched for the Tsi 300. I have it right now, and it's a good center, and should work well for your setup.
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    CS10 or CS20 both would work great for the set up.
