25ft cable
acmf74
I want to purchase a cable for my sub. I know I should keep the distance as short as possible. Would there be any significant sound degradation from a 25ft cable vs a 15ft one?
Thanks.
Thanks.
Post edited by acmf74 on
nope, I've got a 50 footer running to my sub. I used this one. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2684&seq=1&format=2
It's running up my wall, through the ceiling and down the back wall to my sub sitting near-field to the left of my chairs.Pioneer 1018
Polk RTIA5's
CSIA6
RC80I's
SVS PB12-nsd -
Monoprice or Bluejeans cables. I run a 20ft sub cable from BJC with no problems, cost a bit more than the monoprice stuff, but either will work well. My entire HT is built around Signal and BJ cables. Pick your poison, both are great.
http://bluejeanscable.com/store/subwoofer/index.htmShoot the jumper.....................BALLIN.............!!!!!
Thanks all. I picked up a 25ft mono-price cable to test out. If I don't like the results I'll try out the BJC one.
I do have a BJC cable from my CDP to AVR and love it. -
The longer the better IMHO, allows you to find the correct spot for the sub without having to worry about the cable being long enough. I use a 25' cable myself.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
