Sub help
trademark09
I'm trying to find a good sub for my HT and i'm on a tight budget keep it under $600. I've been comparing from Polk's ebay store
Polk micropro 3000 ($510 used or $800ish new)
Polk DSW pro 600 or 500 ($400ish)
Polk PSW 505 ($250 newegg)
Any thoughts? Besides being more expensive how does the micropro compare to 505, where does the DSW pro 600 fit into the mix? And is there any other sub that are better for the money?
Post edited by trademark09 on
trademark09 wrote: »I'm trying to find a good sub for my HT and i'm on a tight budget keep it under $600. I've been comparing from Polk's ebay store
Look at a real sub like Epik, Hsu, eD or SVS. Some can be had for a little more than your budgeted price. These subs will definitely out perform a Polk. Theses are from internet direct companies, so you get mor for the money. Some can even be found used for your price or even under.Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub -
math wizard wrote: »Look at a real sub like Epik, Hsu, eD or SVS. Some can be had for a little more than your budgeted price. These subs will definitely out perform a Polk. Theses are from internet direct companies, so you get mor for the money. Some can even be found used for your price or even under.
Any specific models or are you just name dropping? -
https://svsound.com/store/index.cfm?fuseaction=category.display&category_ID=12
Great deal on a B-stock. Only 1 left.
You won't be disappointed.Things work out best for those who make the best of the way things work out.-John Wooden
