Sub help
I'm trying to find a good sub for my HT and i'm on a tight budget keep it under $600. I've been comparing from Polk's ebay store
Polk micropro 3000 ($510 used or $800ish new)
Polk DSW pro 600 or 500 ($400ish)
Polk PSW 505 ($250 newegg)
Any thoughts? Besides being more expensive how does the micropro compare to 505, where does the DSW pro 600 fit into the mix? And is there any other sub that are better for the money?
Post edited by trademark09 on
  • math wizard
    math wizard Posts: 106
    edited June 2010
    Look at a real sub like Epik, Hsu, eD or SVS. Some can be had for a little more than your budgeted price. These subs will definitely out perform a Polk. Theses are from internet direct companies, so you get mor for the money. Some can even be found used for your price or even under.
    Processor - Emotiva UMC-200
    Pre-Amp (2 Ch) - Emotiva USP-1
    DSP Minidsp nanoAVR DL
    DAC (2 Ch) - Emotiva XDA-2
    Amp (Fronts) - Emotiva XPA-2
    Amp (Center/Surrounds) - Emotiva XPA-3
    CD - Emotiva ERC-1
    Fronts - Polk Audio RTi 12
    Center - Polk Audio CSi5
    Rears - Polk Audio RTiA1
    Sub - Epik Knight
    Sub EQ - Velodyne SMS-1
    Monitor - Sony XBR65X850C
    Blu-Ray - OPPO BDP-203
    Network Media Player - Chromecast Ultra
    Power Conditioner - APC H15
    Power Conditioner - Emotiva CMX-2
    PVR - DirecTV C61k
    Remote - Harmony Touch w/Hub
  • trademark09
    trademark09 Posts: 2
    edited June 2010
    Any specific models or are you just name dropping?
  • PSOVLSK
    PSOVLSK Posts: 5,412
    edited June 2010
    https://svsound.com/store/index.cfm?fuseaction=category.display&category_ID=12
    Great deal on a B-stock. Only 1 left.
    You won't be disappointed.
