wire gauge
j allen
j allen Posts: 363
edited January 2012 in Basic Hookup/Wiring Questions
Okay, I'm not going to mention what kind of wire I'm using, as that leads to a bad, bad place, but I have a wire question. I'm currently using 14 gauge wire for my fronts (app. 6 foot runs) and 18 gauge for my surrounds (app. 25 foot runs). Would it behoove me to go to 12 gauge wire for the surrounds, or will more of the 14 gauge I currently have suffice just fine? I'm going to switch it either way, but I'm unsure of whether the surround runs are long enough to require a bigger wire.
Please assume that the brand and type of wire are irrelevant, and just focus on wire gauge; I don't want this to turn into a hate fest.
You can see my sig if you questions about what sort of equipment I'm currently using.
  • decal
    decal Posts: 3,205
    edited June 2010
    My opinion,14 ga. will be just fine.I'm sure someone will disagree,but that's fine with me.
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited June 2010
    Basically, longer runs require higher gauge...
    I mean just buy a spool of 14 gauge and you should be ok.
    Or, if you wanted...you may or may not get better bass response its a toss up just buy 12 and be had with it.Usually only 5-10 more a spool...
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • John K.
    John K. Posts: 822
    edited June 2010
    JA, this excellent explanation of speaker wire in general includes a table of suggested gauges that you should study. Your TSi 100s are rated at 8 ohms, so even the present 18ga wire is sufficient for that run. Since you already have more 14ga, you can hook it up if you want, but there's no necessity or real advantage in doing so.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited June 2010
    IMHO 18 gage is rather small while 12 gage is rather heavy for home audio use. I think you should use 14 gage all around without any issue.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • PerfectCreature
    edited June 2010
    I think we all agree then. Just keep your 14, buy a little extra and do your system with it then forget about it and enjoy your music and movies.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • j allen
    j allen Posts: 363
    edited June 2010
    Okay, I'll go with the 14awg option. What's up with that link? I've read that article before, but didn't get much out of it...
    My concern was exactly what Keiko said in post #6, that 18awg would introduce resistance to the circuit, thus altering (if not reducing) performance.
    Thanks guys!
    F1nut Posts: 52,368
    edited June 2010
    There's a lot more to good audio cable than gauge.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2010
    I find heavy gauge looks awful on surrounds if your mounting plus its a real pain in the **** to hide along the base board when you have 4
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    LOL, I guess it comes down to do I care how it looks, or how it sounds. :D
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    BlueFox wrote: »
    Let me answer your question with my own experience on this subject.
    At the time, my HT consisted of 4 LSi15s and an LSiC. The amp is on the side wall between the front and rear left speaker. This made the cable runs 7’ to the front and rear left, 9 feet to the center, and 18 feet to the front and rear right speaker.
    At the time I was only using the AVR for power, and it was a Sony STR-DA7100ES (dgital amp 175W/ch). The speaker wire was a mixture of 14-16 gauge generic (clear insulation, twisted copper) speaker wire.
    did the different length of runs make a difference in sound...... because my future set-up will be similar ....also did the 14gauge sound different than the 16....when used together???
    Budget 5.1 H.T. Set Up
    HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
    Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
    Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    sorry i was trying to qoute blue fox but have realized i am a complete dumb dumb
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    my question still stands though
    Custom Jumpers
  • TECHNOKID
    edited June 2010
    j allen wrote: »
    Quoting the OP, he was clear the question is about wire gage NOT a debate on esoteric cables and the GOOD LOOKS so let's stay on topic please ;)
    DARE TO SOAR:
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    question for blue fox.......well lets just say im running all twelve gauge ....should the front three channel all be the same length....wll this affect sound if lengths are different.....same question for rear channels...should the lengths be the same length amongst the front ...and should they be the same amongst the rears????thanks pal:D:cool:
    Custom Jumpers
  • TECHNOKID
    edited June 2010
    Technically all cables should be the same lenght but we are talking home audio and in most cases the the legnth are quite insignificant and will not make really audible difference. Personnally I keep all wires the same gage and lenghts. The only draw back to this is if you have cables looped which can cause other issues.
    DARE TO SOAR:
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    i would honestly like a proffesionals opinion .....honestly guys who wire up ht systems every day for a living .....do they wire custom lengths for each speaker....especially with in-wall set ups......or do they make all lengths the same?????it doesn't seem vry cost effective to run all wires the same length.....
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    i believe mantis is a pro????
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    thanks .....thats the answer i was looking for ......yes my avr has adjustment for speaker distances .....and no i can't hear a nanosecond difference....lol .....i will cut custom lengths to fit each speaker....:)
    Custom Jumpers
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    John K. wrote: »
    Ahh...the good ole Troll Bible...Roger Russel is like a god to some people apparently. He has an article on the internet, so he MUST know what he's talking about. I haven't seen that nonsense article get posted on here for a while.:rolleyes:
    I've heard differences in cables in MY rig with MY ears. According to a lot of people though, I haven't really. I'm just imagining it. Never mind that I've changed my cabling, and had friends over...and without even mentioning that I changed anything in my rig, they've asked me "did you get something new? your stereo sounds better than it used to! The bass output seems stronger!!" I guess my friends must have gotten a "contact placebo affect" just from being in the same room as my "snake oil" cables...regardless of whether or not they knew they were even there.
    Judge with YOUR OWN ears. Some people's hearing isn't good enough to detect the differences in cables apparently...and these people are upset I suppose. That's why they try to rally against us people who can.;) Personally, I'm really glad that I can hear the differences in cables. My AQ's have made a very pleasing difference in my rigs sound, and they made for a very cheap and VERY effective upgrade.:) Contrary to what some of these people say...you don't have to spend $500-1000 to get a set of high end cables, despite how much they like to throw those figures around. Between all of my speaker cables and IC's in my 2 channel rig...I have less than $300 invested in cabling. This includes two pairs of speaker cables, and about 6 pairs of IC's.
    To the OP-You'll be fine with 14 gauge. That's what I've always used for my surrounds, which are about 30' runs. They made for an EXCELLENT improvement over the cheapo 20 gauge I was using before.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    Has anyone tried Romex 15 amp electrical wire .......its probably about 12 -14 gauge solid copper .....in-wall rated ....and carries about the same shielding as your basic in-wall speaker wire ......
    Yes this is a serious question
    Custom Jumpers
  • PerfectCreature
    edited June 2010
    I can agree with the AQ cables, I have about $200 in my cables and everything audio related is AQ, it sounds so much better than before. Mainly it is clear, and well defined.
    I mean really for now though, pick up a spool of 14 and then as budget allows buy better wire. That is what I did and it worked out perfect.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • WilliamM2
    WilliamM2 Posts: 4,812
    edited June 2010
    K-daugh wrote: »
    By code, 14 gauge Romex is rated for 15 amp, 12 gauge for 20 amp. Neither has any shielding, just insulation. It would work fine, but it's a pain to work with, very stiff.
  • TECHNOKID
    edited June 2010
    WilliamM2 wrote: »
    Exactly, I agree with you on all points.
    DARE TO SOAR:
  • TECHNOKID
    edited June 2010
    You are forgetting that any decent AVR allows you to adjust each speaker level to the same SPL. This easily compensates for any cable length variants, and I seriously doubt if you, or anyone else, can hear the micro-pico-second delay between 8’ and 16’.
    That was exatly my point previously... While I have technical training and years of experience, I figure you don't need to be a proffessional installer or even have much schooling to realize that, right (the comments are not pointing at the QP)?
    comfortablycurt;1361599]Ahh...the good ole Troll Bible...Roger Russel is like a god to some people apparently. He has an article on the internet, so he MUST know what he's talking about. I haven't seen that nonsense article get posted on here for a while.:rolleyes:
    Sorry Curt but IMHO, for esoteric-exotic followers it may seem that way however, for the few that may have a little electronic background (schooling I mean, not toying and experimenting WK) this article does makes sense since it goes along with the laws of electronics.
    I'll agree with you that some hearing abilities are a must in order to properly calibrate audio but this is also subjedtive and the brain more than the actual hearing is at play here much more than the actual hearing if you get my drift :rolleyes:
    I found quite the opposite, the esoteric believer rallying and ridiculing people that came in the discussion with just a tad of common sense. As far as I am concerned, the more esoteric believers and buyers the merrier since they are the targetted people for mass profit which leads for much more friendlier pricing on the actual real important gear :cool:
    Now, you finally provide an answer to what the OP was asking not counting he was clear about NOT getting into cable debate. You and some actually derailed the OP, ignoring is request for cable debate and again tried to take a shot against people that don't share your personal beliefs. Faith is NOT imposed, simply shared and proposed ;) Keep in mind that NO NON believer tried to go into cable debates but simply replied to the OP legitimate question, so who actually is bullying and riduculing here? ;)
    I sure hope that the OP got his answers even if is request was ignored, his thread trolled and highjacked :(
    If people could simply learn to get involved in the threads they actually can get along with and limit the info provided to what the actual OP has requested for instead of ridiculing or trying to impose their own views. I've seen the babble on cable and what it can do, I learned to stay away out of what I don't agree with out of respect for the believers, I just wish the participants of cable religions could do the same, especially when requested in the OP. I guess it is too hard for some to be asked.
    Cheers!
    TK
    DARE TO SOAR:
    heiney9 Posts: 25,669
    edited June 2010
    TECHNOKID wrote: »
    I'll agree with you that some hearing abilities are a must in order to properly calibrate audio but this is also subjedtive and the brain more than the actual hearing is at play here much more than the actual hearing if you get my drift :rolleyes: I found quite the opposite, the esoteric believer rallying and ridiculing people that came in the discussion with just a tad of common sense. As far as I am concerned, the more esoteric believers and buyers the merrier since they are the targetted people for mass profit which leads for much more friendlier pricing on the actual real important gear :cool:
    Cheers!
    TK
    Pot, Kettle, Black (Red letters). Funny how your type preach this but never, ever follow your own advice. Just give him an answer, the rhetoric is not needed. You are not the Savior of all things cable.
  • kevhed72
    kevhed72 Posts: 5,206
    edited June 2010
    Just go with 12 AWG and be done. This is more than adequate.
    Another option - go with higher-end speaker cables for the fronts and center for a better, more 'musical' sound for even HT use, and use the standard 12 AWG for the surrounds only. There is really no need to go above standard cable for the surrounds. IMO.
  • Timobi
    Timobi Posts: 7
    edited January 2012
    Will the 12AWG copper wire from monoprice fit my RTi4 and CSi5 Center?
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2789&seq=1&format=2
    Think it will but don't want to use banana plugs. Thanks!
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2012
    Yes... 12 AWG wire is roughly 1/12th of an inch in diameter.
    Now let us pray that this thread quietly sinks back into the depths from which you pulled it...
    More later,
    Tour...
    Vox Copuli
