High-pitched noise coming from center channel
ryanjoachim
ryanjoachim Posts: 2,046
edited June 2010 in Speakers
So, I woke up this morning and I can hear a very loud and constant high-pitched ring coming from the center speaker. It changes in volume when I turn the volume up or down.
This wasn't happening last night, and the TV/surround was off all night long. Any suggestions?
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • ryanjoachim
    edited June 2010
    Odd...
    I turned the receiver off and then back on, to see if the ringing stopped...it didn't.
    I switched the inputs from DVD (which I use for my blu-ray player and my computer) to a different channel...and the ringing stopped. When I switched back to DVD, the ringing was gone.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
    tonyb Posts: 33,072
    edited June 2010
    Check your connections.
  • texas ed
    texas ed Posts: 139
    edited June 2010
    If your center channel cable is long enough,try hooking it up to a front speaker and see if the problem follows it.Try using the front speaker cable as a center channel cable and see if the problem goes away.Recheck the rca center channel connection.That is what I would do for starters.I'm sure these Polk Vet's have other ideas as well. Good Luck, Eddie
