High-pitched noise coming from center channel
ryanjoachim
So, I woke up this morning and I can hear a very loud and constant high-pitched ring coming from the center speaker. It changes in volume when I turn the volume up or down.
This wasn't happening last night, and the TV/surround was off all night long. Any suggestions?
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
Odd...
I turned the receiver off and then back on, to see if the ringing stopped...it didn't.
I switched the inputs from DVD (which I use for my blu-ray player and my computer) to a different channel...and the ringing stopped. When I switched back to DVD, the ringing was gone."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
Check your connections.HT SYSTEM-
lsi 9's -
If your center channel cable is long enough,try hooking it up to a front speaker and see if the problem follows it.Try using the front speaker cable as a center channel cable and see if the problem goes away.Recheck the rca center channel connection.That is what I would do for starters.I'm sure these Polk Vet's have other ideas as well. Good Luck, Eddie
