LSi25 Amplifier
mmenik
I need to purchase a LSi25 amplifier. I need to replace one that is broken; the one I have just screeches static until I unplug it. Any ideas?
My speaker config:
Fronts: LSi25
Rears: LSi15
Center CS350-LS
Email: mmenik@cox.net
My speaker config:
Fronts: LSi25
Rears: LSi15
Center CS350-LS
Home Theater Configuration:
Receiver: Denon AVR-5700
Front: Polk LSi25
Rear: Polk LSi15
Center: Polk CS350LS
Sub: SVS 20-39PC+
DVD: Panasonic
TV: Mitsubishi 65" Rear Projection
Room size: 28' X 28' X 10-14' High
Front: Polk LSi25
Rear: Polk LSi15
Sub: SVS 20-39PC+
DVD: Panasonic
Post edited by mmenik on
Have you tried Polk customer support? You might be surprized"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
Yes, I tried customer support...they were very helpful. They told me to take a phiilips head screwdriver and remove the amplifier from my LSi25 and take it into a repair place. I went into Best Buy and they have to send it out of state (I'm in Nevada) to get it fixed. I could not find anyone else locally to do this type of work. Nor do I know where I can but a replacement amplifier. so I thought I would check out this Polk forum...Thanks for the reply.Home Theater Configuration:
Front: Polk LSi25
Rear: Polk LSi15
Sub: SVS 20-39PC+
DVD: Panasonic
Room size: 28' X 28' X 10-14' High -
Don't send it in with Best Buy... that's a terrible choice.
Find a local electronics repair shop, and get a quote. It will probably run you $50-100.11.3 Theater
RTi A7 Fronts - CSi A6 Center - 65-RT DSX Wides - RTi A1 DSX Highs - FXi A6 Rears - FXi A6 Surround Backs
eD A5-350 (L-LFE) - eD A5-350 (R-LFE) - SVS 20-39+ (Rear-LFE) - Aura Pro x 8 Seats
Onkyo TX-NR3010 (11.3 Neo:X) - Sony TA-N9000ES Amplifier
JVC RS-20u - Elite 120" 1.3 Gain - XBMC Processor - TrippLite 30A Full Theater Backup
2.1 Studio / PC
Mackie HR824 Powered Monitors - Infinity Kappa Perfect 12" DIY
Aune USB 24/192 DAC HPA - Sennheiser HD650/600 -
...Or you could just order a replacement from Polk perhaps?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I am considering calling Polk and orering a replacement amplifier; tried to remove the amplifier but it would not release. Is it glued in to seal it? If I were to get a rplacement amplifier, how would I repalce it. Are there any special instructions or do I need a certified Polk repair tecnician to deal with this.Home Theater Configuration:
Front: Polk LSi25
Rear: Polk LSi15
Sub: SVS 20-39PC+
DVD: Panasonic
