LSi25 Amplifier
mmenik
mmenik Posts: 18
edited June 2010 in Wanted (WTB) Classifieds
I need to purchase a LSi25 amplifier. I need to replace one that is broken; the one I have just screeches static until I unplug it. Any ideas?
My speaker config:
Fronts: LSi25
Rears: LSi15
Center CS350-LS
Email: mmenik@cox.net
Home Theater Configuration:
Receiver: Denon AVR-5700
Front: Polk LSi25
Rear: Polk LSi15
Center: Polk CS350LS
Sub: SVS 20-39PC+
DVD: Panasonic
TV: Mitsubishi 65" Rear Projection
Room size: 28' X 28' X 10-14' High
Post edited by mmenik on
  • sucks2beme
    sucks2beme Posts: 5,683
    edited June 2010
    Have you tried Polk customer support? You might be surprized
  • mmenik
    mmenik Posts: 18
    edited June 2010
    Yes, I tried customer support...they were very helpful. They told me to take a phiilips head screwdriver and remove the amplifier from my LSi25 and take it into a repair place. I went into Best Buy and they have to send it out of state (I'm in Nevada) to get it fixed. I could not find anyone else locally to do this type of work. Nor do I know where I can but a replacement amplifier. so I thought I would check out this Polk forum...Thanks for the reply.
    Front: Polk LSi25
    Rear: Polk LSi15
    Sub: SVS 20-39PC+
    DVD: Panasonic
  • theta
    theta Posts: 51
    edited June 2010
    Don't send it in with Best Buy... that's a terrible choice.
    Find a local electronics repair shop, and get a quote. It will probably run you $50-100.
    11.3 Theater
    RTi A7 Fronts - CSi A6 Center - 65-RT DSX Wides - RTi A1 DSX Highs - FXi A6 Rears - FXi A6 Surround Backs
    eD A5-350 (L-LFE) - eD A5-350 (R-LFE) - SVS 20-39+ (Rear-LFE) - Aura Pro x 8 Seats
    Onkyo TX-NR3010 (11.3 Neo:X) - Sony TA-N9000ES Amplifier
    JVC RS-20u - Elite 120" 1.3 Gain - XBMC Processor - TrippLite 30A Full Theater Backup
    2.1 Studio / PC
    Mackie HR824 Powered Monitors - Infinity Kappa Perfect 12" DIY
    Aune USB 24/192 DAC HPA - Sennheiser HD650/600
    nooshinjohn Posts: 25,926
    edited June 2010
    ...Or you could just order a replacement from Polk perhaps?
  • mmenik
    mmenik Posts: 18
    edited June 2010
    I am considering calling Polk and orering a replacement amplifier; tried to remove the amplifier but it would not release. Is it glued in to seal it? If I were to get a rplacement amplifier, how would I repalce it. Are there any special instructions or do I need a certified Polk repair tecnician to deal with this.
    Front: Polk LSi25
    Rear: Polk LSi15
    Sub: SVS 20-39PC+
    DVD: Panasonic
