Sunfire cinema grand power requirements
polkfarmboy
I am buying amp for HT and was looking at various brands and saw this on the gon
My question is what kind of juice do these amps need to have them sing ?
Do you need special modifications done to the fuse box ?
How can you tell what amp needs modifications done to the fuse box?
Post edited by polkfarmboy on
They are incredibly efficient, actually. IF you're going to run at the ragged edge, however, I'd run a dedicated 15 amp circuit at minimum. Are you talking standard or Signature model? What is the rest of your system makeup?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I ran mine on a 15amp circuit, along with the rest of my theater equipment, and they tripped only on rare occasion. If you're on a 20amp, you should be in great shape.
I run my 425x5 Sunfire on a 15amp with no troubles, but when I run my LSi's up front it can cause the lights to dim... I would say it depends on the speakers a bit as well. If you run 4ohm speakers a 20 amp circuit is not a bad idea.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I run my sig seven off a 20A Circuit and have not had one problem with it.
Shannon50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
Standard wall outlet will be just fine. If you want you can run a dedicated line, but that's to get a less noisy outlet, not because the amp requires any special power needs.
I power all of my listed gear off a single 20 amp circuit. A second would be better but I've never had any issues even when hitting the PowerGuard on my amps.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
