Sunfire cinema grand power requirements
polkfarmboy
polkfarmboy Posts: 5,703
edited June 2010 in Electronics
I am buying amp for HT and was looking at various brands and saw this on the gon
My question is what kind of juice do these amps need to have them sing ?
Do you need special modifications done to the fuse box ?
How can you tell what amp needs modifications done to the fuse box?
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2010
    They are incredibly efficient, actually. IF you're going to run at the ragged edge, however, I'd run a dedicated 15 amp circuit at minimum. Are you talking standard or Signature model? What is the rest of your system makeup?
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2010
    I ran mine on a 15amp circuit, along with the rest of my theater equipment, and they tripped only on rare occasion. If you're on a 20amp, you should be in great shape.
    nooshinjohn Posts: 26,178
    edited June 2010
    I run my 425x5 Sunfire on a 15amp with no troubles, but when I run my LSi's up front it can cause the lights to dim... I would say it depends on the speakers a bit as well. If you run 4ohm speakers a 20 amp circuit is not a bad idea.
  • Shannon W.
    Shannon W. Posts: 568
    edited June 2010
    I run my sig seven off a 20A Circuit and have not had one problem with it. :)
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
    heiney9 Posts: 25,721
    edited June 2010
    Standard wall outlet will be just fine. If you want you can run a dedicated line, but that's to get a less noisy outlet, not because the amp requires any special power needs.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited June 2010
    I power all of my listed gear off a single 20 amp circuit. A second would be better but I've never had any issues even when hitting the PowerGuard on my amps.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
