Mono-block is toast
BuckeyeTim
So one of my amps is on the fritz again. I am about to give up on it. I just brought it home from being serviced for the second time in 3 months and it still has issues.
If you remember, I had it serviced a few months ago for a crackling static noise. The shop I took it to said that the board had begun to carbonize due to the years ago problem with leaking caps. They had to separate some components from the board and hardwire them to get around the bad parts of pc board.
All was good for about a month when all of a sudden the distortion light would come on at power-up and then fade away. Everything still sounded fine and dandy. After several weeks of this, it started to develop the static/crackle.
I decided to take it to a local place. They guy spent 2 weeks replacing a couple more caps and then using a very fine tip on a Dremel to try and grind away the carbonization between some of the traces on the board. He thought he had it taken care of, but as soon as I fired it up....the same problem exists. Distortion light comes on and then the static and crackling.
I think I am about to give up on it. Unless I can find another board (which I doubt) or I can find someone that wants to part with a single one (which I doubt)...I think I am screwed.
I guess it is time to find another amp/amps.
Post edited by BuckeyeTim on
Try contacting Ben, he has worked on Adcom's in the past.
+1^^
You should also ask the guy who repaired it if he stripped the boards of ALL the old parts,cleaned the boards in a sonic bath and then repopulated the boards with ALL NEW caps,resistors,etc..SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Wew, I would sell those puppies. The working unit would make a killer amp for a passive subwoofer.
Conradicles wrote: »Wew, I would sell those puppies. The working unit would make a killer amp for a passive subwoofer.
No reason to give up on them yet. I would find someone that knows how to fix them properly, they're worth it. -
shoot me a PM if you want them fixed.
Ben -
Ben
On its way Ben, and thanks for the offer. I love these things and would be heart broken to have to retire them. -
Geez Ben, what don't you do? lol- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
Plumbing and sheet rock.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
LOL do you know of a good person I can send a vintage receiver to if I want it restored?- Jeremy
I never worked on vintage receivers minus a few Adcom's.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I spoke to Ben for a few minutes earlier today and it looks like my amp is heading south for repairs. I just hope that it is not beyond fixable.
Thanks to Ben for even offering to look at it! This one of those things that makes CP so great...the people. -
Good on Ben he's a generous lad with his time and talents for sure.Hopefully the tech did'nt monkey it completely.
