When to recap a pre-amp
Fongolio
I have a Carver C-1 pre-amp and a SAE Two PA-10 pre-amp in the mail. Both are 25 years or so old. My question is how does a person know when it's time to re-cap them? What will I hear or not hear? Which caps do you replace and what do you replace them with? To my ears the Carver still sounds great but at 25 plus years those caps must be nearing the end of their usable life. Thanks for any input.
Kelvin
Kelvin
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Post edited by Fongolio on
When it is bad enough to hear some crackling you have gone way past the rebuild time. I am recapping my GFA-565 mono blocks soon. Still sounds good, but I know it can be improved with new better caps. 20 years it is do for a rebuild.
Ben -
Guys,,I cannot say enough about the Clarity MR's that I just put in my pre.
They are that good.JC approves....he told me so. (F-1 nut) -
The presence of 120hz hum is one indicator of main filter cap issues and apparent lack of bass can happen with aged electrolytics used for input/ output coupling and feedback duties.My question is how does a person know when it's time to re-cap them?
Look at replacing any electrolytics especially the main filter caps and those in the signal path.Replace power supply caps with electrolytics of the same value.Replace any electolytic coupling caps with good film caps if there is room enough on the PC board to do so.Which caps do you replace and what do you replace them with?
