SDA for me?
Hawkeye
I've been reading about the SDA around here for ages. I've been thinking it over and found that pair of SDA SRS 1.2's on ebay. I'm sure you've all seen them by now.
The seller is about two hours from me and am wondering if this speaker is a good choice for getting into the SDA line up and is it a reasonable price?
Gordon
Gordon
2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
Post edited by Hawkeye on
The SDA-SRS is always a great way to get into them. Nothing like starting off on top if you have the room for them and the approval of the higher authority.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Go for it Gordon! If you don't care for them, just set them out at the end of your driveway... won't take me more than a couple of hours to get there...
Go for it!!!! Remember you can't run them with mono's unless you have an AI-1 cable. I see in your sig you have plural amp(s). I assume they are mono's unless you bi-amp.
Yes, my amps are mono's. The add says an interconnect is included, does that meet the definition of an AI-1 or is the AI-1 something different?
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Gordon
Something different. The AI-1 has an isolation transformer so mono's and non-common ground stereo amps can be used with SDA's. They can be built fairly easily as Darqueknight and Ben have a couple of detailed DIY threads. Occasionally they come up forsale on ebay but not too often.
P.s. Don;t let this discourage you."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
You may also be able to strap the negative outputs of the amps togetherThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Some mono blocs can have their negative outputs strapped,it's those that use a bridged output config. that can't.Check with Mac on your models and to see if they are sutable for strapping.
So, just to get this straight, I'll need either the AI-1 to use my mono's or, another common ground amp.
Could I use the mono's without the interconnect for a period of time while putting together an AI-1?
I'm sure these are dumb questions which have been asked before but my search abilities are lacking!
Gordon2 Channel -
nooshinjohn wrote: »You may also be able to strap the negative outputs of the amps together
Might be possible. It's rare you can do it with some mono's, but call someone very familiar with Mac gear to be sure or you and/or amps will go out in a blaze of glory
Make sure you explain what you are doing and that you have SDA's. There are some L and R channel schematics available. When I was researching my Pass Labs Aleph 30 amp I sent the full SDA schematics to Nelson Pass and asked if the Aleph was common ground for the purpose of running SDA's.
There are different interpretations of the phrase "common ground" so if you know a competent Mac tech or can contact Mac themselves send along the schematics.
See schematics here:
http://www.polkaudio.com/forums/showpost.php?p=677959&postcount=5
See AI-1 build tutorial here:
http://www.polkaudio.com/forums/showpost.php?p=677960&postcount=6
Gordon
1) follow suggestions already given to use mono's
2) yes, but you some loose output and no SDA. To me they don;t sound good w/o the cable..........but you won't hurt anything
3) I provided a couple links, but DK and his build thread is like 10-15 pages."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Go for it Gordon. You can take care of all the other issues later.
One suggestion though, call Mac and ask if the two monos can be strapped together i.e., the negative speaker posts of each mono wired to each other also it might be helpful to find out of the chasis can be strapped also. I did this when I had my Adcom 565 monos and it worked out really well. -
I'll bid on them and see what happens. In the mean time, I'll do a little more reading about this AI-1 cable.
Thanks for the info guys.
Gordon2 Channel -
For all you know Gordon it may come with the AI-1 cable. Mine did! How's their condition?
Guy says he is original owner and there is a snag in part of the fabric.
I've read over the Dreadnaught thread a couple times and I'm confused. Not hard for me! Where in the world does this thing go? Between the amps and speaker? Does one still use the interconnect cable in addition to the AI-1?
I want to get these in the house and see what it's all about. I feel like such a newb
Gordon2 Channel -
hearingimpared wrote: »For all you know Gordon it may come with the AI-1 cable. Mine did! How's their condition?
Some later 1.2 and 2.3's came with the AI-1 and some of the TL models came with AI-1's but mostly they were sold as an accessory.
Gordon, the AI-1 IS the interconnect it just has an isolation transformer in between the speakers as part of the interconnect cord. So no, if you get an AI-1 use that instead of the standard interconnect cord.
Gordon
Snags are nothing to worry about. If you need to go the Dreadnaught route, we'll get you through, so no worries.Some later 1.2 and 2.3's came with the AI-1 and some of the TL models came with AI-1's but mostly they were sold as an accessory.
^^^^^^ What he said! Yeah I guess I lucked out with me getting and AI-1with a set that just had 50 hours on them and in super mint condition. -
Wow, an original owner, local set....go for it!
Be prepared to see the bids go over $2K in the final moments of bidding if prior auctions are any example.SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
Good luck with the bidding Gordon.
I would suggest using the AI-1 "Dreadnaught" opposed to strapping the amps. Much, much better SDA effect and better sound quality overall. Just my thoughts, but do what fits better for you.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Go for it, you won't be disappointed. I drove 1200 miles once to pick up a pair of these and it was totally worth it.
You need to hear a pair that are properly set up sometime. If you get these your biding on, your in for a treat! I just know you need great components for these to really sing their best.Most people just listen to music and watch movies. I EXPERIENCE them.
madmax
Yep, I drove from Philly to Medford MA (just north of Boston), 18 hours round trip. Worth every mile.;) -
Well, if I win these, the drive is only about two hours one way. Driving the beltway around DC is a hit or miss. Sometimes it moves, sometimes not.
Showed my wife these and she noted that they will blend in with all the room treatments
Gotta love a woman who is into the hobby!
Gordon2 Channel -
Gordon
WAAAAAAAAAAAA! When my son and I pulled up and started to unload them around midnight that night, my wife took one look at them and said, "they are scaring me!":eek: -
hearingimpared wrote: »WAAAAAAAAAAAA! When my son and I pulled up and started to unload them around midnight that night, my wife took one look at them and said, "YOU are scaring me!":eek:
Fixed it for ya!;):DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Quote:Originally Posted by hearingimpared
WAAAAAAAAAAAA! When my son and I pulled up and started to unload them around midnight that night, my wife took one look at them and said, "YOU are scaring me!"nooshinjohn wrote: »Fixed it for ya!;):D
HEHEHE! That happens almost every night!:eek::eek::D:p;) -
Hawkeye, the 1.2's are up to the $1800 mark on ebay with an hour to go. If you are not the highest bidder, then "if I were you" it's a good time to throttle down. You can have 1.2TL's for this price, so there are becoming overpriced. I know they are close by and that pulls a lot of weight, but deals pop up on craigslist more often than you think. Just my 2 cents if your looking for advice.
There is also a set of SDA-CRS's on ebay going for $500+....good day for SDA's:) -
Wow! that was interesting. I've never bid on anything on ebay before so I guess that is why somebody else got them!
Thanks for all the info guys, especially Joe. I don't give up that easily, I'll keep looking!
Gordon2 Channel -
What was the final price ?????
$1985.12
Gordon2 Channel -
