Spade lugs: screw, crimp or solder?
Echosphere
Echosphere Posts: 395
edited June 2010 in DIY, Mods & Tweaks
Just curious what favorite method is?
Post edited by Echosphere on
  • Face
    Face Posts: 14,340
    edited June 2010
    Crimp, then solder for the best and most secure connection.
  • Echosphere
    edited June 2010
    That's what I've done in the past... I found these copper spades with screws for 10 of them for $17, but really not excited about the screws. I would think they always come loose with twisting?
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120503622757&ssPageName=STRK:MEWAX:IT
  • ShinAce
    ShinAce Posts: 1,194
    edited June 2010
    Face wrote: »
    +9/10
    For home audio, crimp and solder for both stranded and solid wire.
    For car audio(read: vibration), proper crimp using stranded wire only.
  • Face
    Face Posts: 14,340
    edited June 2010
    Echosphere wrote: »
    Check these out: http://soniccraft.com/products/connections/spade/vampire.htm
  • Echosphere
    edited June 2010
    ShinAce wrote: »
    +9/10
    Thanks you two!
    Even with the good price, thanks to your confirmation, I'm going to pass on them.
    Cheers!
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited June 2010
    I was told soldering makes the speakers sound worse...I don't remember who said it but it was someone on this forum...I know I read it somewhere...
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • Face
    Face Posts: 14,340
    edited June 2010
    There are MANY solder joints between your source and speaker.
  • PerfectCreature
    edited June 2010
    Then I wonder what they were talking about....
    I really do not remember...could it just have been what you solder with? That effects the sound or...does it not matter.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • Echosphere
    edited June 2010
    Face is right.
    But what I think that people were referring to above, and what I usually do, is that you crimp the cable onto the spade then apply some solder over it and and a bit around it. Helps to keep them in there tight, more contact area and seals the copper to stop oxidization. You still have good solid copper on spade contact.
  • PerfectCreature
    edited June 2010
    Hmmm....I do wonder then what they were meaning.
    Oh well, I know now. :D
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited June 2010
    i was told soldering makes the speakers sound worse...i don't remember who said it but it was someone on this forum...i know i read it somewhere...
    what!!!!!!!!!!!!!!!!! can you repeat that
    Seriously though, that would mena that all audio gear makes speakers sound worse, solder all over those darn things, right, :confused::eek:;)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Echosphere
    edited June 2010
    Could they have been talking about bare wire connections?
    Some folks "tin" their bare wire connections to help keep them fraying especially when plugging into those old push pin amp connections. Alot of folks say don't do that, as the solder connection is not as good as direct copper on stereo connector.
  • ben62670
    ben62670 Posts: 15,969
    edited June 2010
    I "tin" the leads with silver solder and use a screw and then solder. If it is a crimp connector I tin the leads, crimp and solder.
    Ben
  • PerfectCreature
    edited June 2010
    Echosphere wrote: »
    I think you just hit it dead on. That rings a bell.
    Yeah...it was something along those lines yep.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • TECHNOKID
    edited June 2010
    Echosphere wrote: »
    Don"t forget the connector and copper actually makes contact but the solder makes a bond to make sure it provides maximum contact, the bonding will not allow for vibrations to create intermiitent problems (which can be hard to troubleshoot). Bonding the strands ensure that the conduction is maximised, not partial. The wire being tinned, chances of wire corosion is minimal. Yet lead solder is not as conductive as pure copper (minimal effect on that scale) therefore Ben's pointing out toward using silver solder will eliminate this problem since silver is a better conductor than copper (you are actualling plating the condudtor which is actually what manufacturers do at high price for their high end cables.
    Cheers!
    TK
    DARE TO SOAR:
  • Echosphere
    edited June 2010
    TECHNOKID wrote: »
    Cheers!
    TK
    Thanks TK & Ben, Together that does make very good common sense.
    Just to play devils advocate, also remember reading once, maybe it was Rita who does repair with Bob Carver, who said that crimping or clamping down, such as in those old push pin connecters, were designed for stranded bare copper as the point of contact from spreading out and solidly "squishing" in the copper to the connector is optimal. Probably makes sense too if you had silver strands. Don't yell at me about it, tend to agree with the two of you, but I just also thought that made sense also.
