Spade lugs: screw, crimp or solder?
Echosphere
Just curious what favorite method is?
Post edited by Echosphere on
Crimp, then solder for the best and most secure connection."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
That's what I've done in the past... I found these copper spades with screws for 10 of them for $17, but really not excited about the screws. I would think they always come loose with twisting?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120503622757&ssPageName=STRK:MEWAX:IT -
+9/10
For home audio, crimp and solder for both stranded and solid wire.
For car audio(read: vibration), proper crimp using stranded wire only. -
Check these out: http://soniccraft.com/products/connections/spade/vampire.htmEchosphere wrote: »That's what I've done in the past... I found these copper spades with screws for 10 of them for $17, but really not excited about the screws. I would think they always come loose with twisting?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120503622757&ssPageName=STRK:MEWAX:IT"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
+9/10
Thanks you two!
Even with the good price, thanks to your confirmation, I'm going to pass on them.
Cheers! -
I was told soldering makes the speakers sound worse...I don't remember who said it but it was someone on this forum...I know I read it somewhere...Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
There are MANY solder joints between your source and speaker."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Then I wonder what they were talking about....
I really do not remember...could it just have been what you solder with? That effects the sound or...does it not matter.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Face is right.
But what I think that people were referring to above, and what I usually do, is that you crimp the cable onto the spade then apply some solder over it and and a bit around it. Helps to keep them in there tight, more contact area and seals the copper to stop oxidization. You still have good solid copper on spade contact. -
Hmmm....I do wonder then what they were meaning.
Oh well, I know now.
Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
what!!!!!!!!!!!!!!!!! can you repeat thatperfectcreature wrote: »i was told soldering makes the speakers sound worse...i don't remember who said it but it was someone on this forum...i know i read it somewhere...
Seriously though, that would mena that all audio gear makes speakers sound worse, solder all over those darn things, right,
:eek:;) DARE TO SOAR:
PerfectCreature wrote: »Hmmm....I do wonder then what they were meaning.
Could they have been talking about bare wire connections?
Some folks "tin" their bare wire connections to help keep them fraying especially when plugging into those old push pin amp connections. Alot of folks say don't do that, as the solder connection is not as good as direct copper on stereo connector. -
I "tin" the leads with silver solder and use a screw and then solder. If it is a crimp connector I tin the leads, crimp and solder.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Echosphere wrote: »Could they have been talking about bare wire connections?
I think you just hit it dead on. That rings a bell.
Yeah...it was something along those lines yep.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Don"t forget the connector and copper actually makes contact but the solder makes a bond to make sure it provides maximum contact, the bonding will not allow for vibrations to create intermiitent problems (which can be hard to troubleshoot). Bonding the strands ensure that the conduction is maximised, not partial. The wire being tinned, chances of wire corosion is minimal. Yet lead solder is not as conductive as pure copper (minimal effect on that scale) therefore Ben's pointing out toward using silver solder will eliminate this problem since silver is a better conductor than copper (you are actualling plating the condudtor which is actually what manufacturers do at high price for their high end cables.Echosphere wrote: »Could they have been talking about bare wire connections?
Cheers!
TKDARE TO SOAR:
Cheers!
TK
Thanks TK & Ben, Together that does make very good common sense.
Just to play devils advocate, also remember reading once, maybe it was Rita who does repair with Bob Carver, who said that crimping or clamping down, such as in those old push pin connecters, were designed for stranded bare copper as the point of contact from spreading out and solidly "squishing" in the copper to the connector is optimal. Probably makes sense too if you had silver strands. Don't yell at me about it, tend to agree with the two of you, but I just also thought that made sense also.
