Which Speakers would U keep?
dhart86
dhart86 Posts: 1,594
edited June 2010 in Speakers
I'd like to take a poll and see what you guys think. Since I joined this forum I have discovered that you guys have a wealth of knowledge and experiences. I know that sound is a personal choice but I need you feedback.
I just got a nice pair of SDA-2A's, they sound pretty good, I also have a pair of Monitor 70's (7 mos old) and a pair of LSi 7's. I will be keeping 2 pairs. If you were me, which pair of speakers would you part with?
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited June 2010
    I may be interested in the m70s if you end up getting rid of them... what color are they?
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • dkg999
    dkg999 Posts: 5,647
    edited June 2010
    If you are keeping speakers for music and for HT, then I would keep the LSi7's for music and the Monitor 70's for HT. If there's no possibility of adding a good musical sub to the LSi7's for a music focused system, then I would consider keeping the SDA-2A's for music. You've got good speakers to choose from, a lot is going to depend on what you will be using them for. We also don't know what gear you've got to run them, which could also alter the recommendations.
    And let the SDA fanatics start the bashing! Yes, I would keep the LSi7's paired with a good musical sub over the SDA-2A's. And yes, I owned SDA-2A's for many years. And yes I own LSi7's and good sub(s) to use with them. So I'm hiking up my big boy panties and sticking to that recommendation.
    DKG999
  • devani
    devani Posts: 1,497
    edited June 2010
    since Lsi7 is already XO modded, it makes sense even more to keep them....you just got SDA 2 and monitor 70
    just keep all three...
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
    nooshinjohn Posts: 25,930
    edited June 2010
    keep the Lsi's and the SDA's.
  • dhart86
    edited June 2010
    Yeah Devani... the Lsi 7's XO's just got modded and are enroute, I probably will keep those.
    Main Rig:
    Second Rig:
  • dhart86
    edited June 2010
    Hey Lietuvis91, the M70's are black, they may be the ones that go. However, shipping these bad boys may cost a good .01
    Main Rig:
    Second Rig:
  • dhart86
    edited June 2010
    Guys, what speakers do you recommend for HT?
    Main Rig:
    Second Rig:
  • dhart86
    edited June 2010
    I hear ya dkg999
    Main Rig:
    Second Rig:
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    Keep the LSi's and the SDA's.
    No contest.
    The Monitor 70's are pretty nice speakers, but they can't stand up to the LSi's or SDA's for either 2 channel or HT IMO.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • dhart86
    edited June 2010
    The more I listen, the more confused I get regarding which speakers to keep. To me the Lsi7 and SDA are superior for music. But I really like the M70's for HT and music. M70's seem like a great utility speaker that would be good both ways. I'm thinking I can get a lot of mileage out of them. I just got the SDA's and they are starting to grow on me for music (had not considered for HT).
    Nooshinjohn and comfortablycurt thanks, I have read alot of your previous post and value your opinions as informed and knowledgeable.
    I still would like more opinions, I guess I just like the versitility of the 70's
    Main Rig:
    Second Rig:
  • Lietuvis91
    edited June 2010
    dhart86 wrote: »
    oh man.... i need the cherrywood ones... oh well
    edited June 2010
    You've got three pretty different and nice speakers there. I agree with you M-70s can do double duty...but the LSis are really better for music (I like the 7s quite a bit in the configuration dkg999 suggests above!)
    The question I have is what 'shape' are your SDA's in because if they're not modded and need work you need to consider the cost and what you're willing to put into them. Are they better than the M-70s..sure..with the RDO-194 replacement. I have SDA-2Bs with the SL2000 and the M-70 tweeter sounds better to me..smoother. But certainly the SDAs put out more sound, better bass and then there's the effect?
    Tough call.
    cnh
  • dhart86
    edited June 2010
    cnh,
    you make a great point about the M70 vs SDA. I wasn't clear to me until u said it, but M70 tweeter is much better, but SDA puts out more sound. I guess that's where I'm having difficulty. I am not really a bass head but do need some to round out the bottom end of the spectrum. Also the SDA are not modded. Is it a dramatic difference in the modded SDA?
    Main Rig:
    Second Rig:
  • comfortablycurt
    edited June 2010
    dhart86 wrote: »
    cnh,
    I assume that your SDA's still have the stock SL2000 tweeters...if so, upgrade them to the RD0-194's!! They're a vastly superior sounding tweeter. If you swap the 194's into your SDA's, you won't be preferring the highs from your M70's any longer.;)
    IMO, out of those three speakers...the SDA's would be the best for pulling HT/2 channel double duty.
  • dhart86
    edited June 2010
    Thanks for all the input everyone! After much listening, I have decided to let the M70's go! I'll miss'em
    Main Rig:
    Second Rig:
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2010
    I've never heard the LSi7 or Monitor 70 (In a real listening environment...meaning, not Fry's or Circuit City demo rooms), but I've heard the SDA 2A and I think you'll be happy with your choice.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    Oh Yeah! The SDA 2's with the new tweeters! That will be best IMHO. I think you made the right choice.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • dhart86
    edited June 2010
    John & Doug, thanks for the vote of confidence. I'm trying to hone in on some rdo194 tweets and move on to better listening. Has anyone had the original tweeters and then the rdo194's in their SDA-2a's? Can you tell me how much of a difference it made for you
    Main Rig:
    Second Rig:
