PSW505 to Onkyo NR-807 with Sub Pre Out
Miles
Miles Posts: 3
Trying to understand how to best connect my PSW505 to my Onkyo TX NR-807 receiver.
I have two sub pre outs on my receiver. Do I connect one sub pre out from my receiver to the Line In left and and the other sub pre out to the Line In right on my PSW505 sub? From what I've read the receiver sends the same signal out of both and I'm assuming the Line In left and right pick out the frequencies on the sub.
I'm hoping this is the best way to hook up the sub. I purchased the RCi in-wall speakers for the front and the rear.
Thanks in advance, Miles
Post edited by Miles on
  • cnoat
    cnoat Posts: 315
    edited May 2010
    ...+1
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • Miles
    Miles Posts: 3
    edited May 2010
    It probably comes down to not really understanding sub out and pre out well enough and perhaps trying to follow the instructions too closely. On page 3 of the manual, figure 8, it says that one would use the "Sub Out" feature to connect to the LFE input. On page 4, figure 9, it says that "Pre Out" jacks connect to the left and right line level inputs. My understanding is that I have pre out jacks on my receiver so I guess this is why I'm still confused. Thanks, Miles
  • zeppage2
    zeppage2 Posts: 196
    edited May 2010
    The preouts would be used for an external amp. Follow xcapri79's advice.
  • ibewbrother
    ibewbrother Posts: 186
    edited May 2010
    Think of it this way....with the internal crossover in the 807..your sub-outs are your lows, and the other 7 pre-outs are your highs....
    "Making life enjoyable through expensive electronics." BillD
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
    Carver TFM-45 (mains)
    Carver A753x (center, surround)
    320GB PS3, 42" Panasonic G10,
    M60's as a Zone 2 off of the Pioneer in the living room
    R.I.P. Onkyo TX-NR807
  • Miles
    Miles Posts: 3
    edited May 2010
    Thanks to everyone and to xcapri79s original response which I'll go with. Can I use speaker wire to make the rca jack connection (assuming I go to Radio Shack)?
  • Freak When C
    Freak When C Posts: 231
    edited May 2010
    Dude, c'mon :rolleyes: That question does not even deserve a straight answer. You're not really that clueless, are you? :eek:
  • ibewbrother
    edited May 2010
    If you bought a 807 then you should have a few RCAs laying around somewhere....get ONE and hook it up.....if it is stereo, split it......LOL
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited May 2010
    Hello Miles,
    Welcome to Club Polk. The best connection method is to use a shielded coaxial cable to go from either one of the two sub-out connections, on the receiver, to the single LFE input on the sub-woofer. This connection needs to be a coaxial type cable rather than speaker wire. I'm afraid speaker wire could result in humming from lack of sufficient grounding. If you've already run speaker wire, through walls, then instead of a line level connection connect the positive/negative speaker wire to either the right or left main speaker connection, on the receiver. Then, at the sub-woofer end, connect the positive/negative speaker wire to either the right or left speaker level input on the sub-woofer. You would also want to set the receiver's set-up instructions to sub-woofer "off" with this connection.
    If you are using the coaxial cable connection then the receiver would be set with the sub-out function on.
    I hope this helpful information.
    Cheers, Ken
  • geebolt
    geebolt Posts: 215
    edited June 2010
    I have the axact same combo. I did what is suggested above. One of the subwoofer outs to the LFE in on the sub. Works great.
    George
    Fronts: Polk RTi A7's
    Center: Polk CSi A6
    Surrounds: Polk TSi500's
    Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
    Amplifier: Emotiva XPA-5
    Processor/AVR: Emotiva UMC-1
    DAC: Emotiva XDA-1
    CD player:Emotiva ERC-1
    Blu-Ray: Oppo BDP-93
    Turntable: Kenwood KD-500
    Tonearm: Polk-Mayware Formula 4
    Cartridge: Shure M97-XE
    Television: Sony KDL-55EX500
  • [Deleted User]
    edited June 2010
    Good, George, I'm glad you were able to get things working.
    Enjoy, Ken
