25ft RCA Cable from Preamp to Amp - Bad Idea?
thor098
thor098 Posts: 38
Hey guys,
I upgraded to a Parasound 1500a amp this weekend and the thing is huge. I need to find a different location for it. I have a place but it would require a 25 ft RCA cable.
Bad idea?
P.S. The Parasound amp is incredible. Wow!
2 CH
Parasound 2100 preamp
Polk Lsi15s
powered by a
Parasound HCA 1500a
2 Passive JBL 10" Subs
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
2 Passive Polk 10" Subs
powered by ADCOM 545
Post edited by thor098 on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited May 2010
    Hello Thor,
    That's going to depend upon some variables of the pre-amp, power amp and the connecting cables. You would need to know the output impedance of the pre-amp, the input impedance of the power amp and the characteristic impedance of the connecting cable. The lower the output impedance of the pre-amp the better for longer runs.
    Regards, Ken
  • Echosphere
    Echosphere Posts: 395
    edited May 2010
    Congrats on the amp!
  • thor098
    thor098 Posts: 38
    edited June 2010
    Just and FYI: I tried a Monster 20ft series 300 cable. I got it on sale for $12.00. There was a signifcant difference in the sound quality. I would describe it as the "punch" was gone. Everything was still there - it just wasn't the same "wow" factor that I experinced with a 6 ft cable. And believe me, I wanted to make it work.
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • Echosphere
    edited June 2010
    thor098 wrote: »
    I know alot of people don't like the Monster stuff but in this I would surmise it's the length. Get the gear closer together if you can.
  • Face
    Face Posts: 14,340
    edited June 2010
    I would give Frank at Signal Cable a call: http://signalcable.com/
  • thor098
    thor098 Posts: 38
    edited June 2010
    Just an update: I returned my Monster Cable and tried a 24' Rocket Fish from BestBuy. This cable didn't work at all. I would get a signal and then I wouldn't. Then one side, then the other. I assume the signal was on the lowest end of the acceptable strength. I then took that back and took a chance on a cheep $13.00 (normal price) 20' cable from Radio Shack. Guess what - it works and I hear no loss in the sound. How strange is that?
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2010
    thor098 wrote: »
    Well that's good to hear.
    It just goes to show that cables do make a difference.
    I would like to add one more thing; despite the fact that the Rat Shack cables are working for you, I would still give Frank at Signal Cable a call and see what he recommends for your situation in-case down the line the cables you are using now fail . . . at least you'll know ahead of time what other options you have that will keep you rig running without having to worry or have to go on another search for a fix.
  • thor098
    thor098 Posts: 38
    edited June 2010
    One final update. I ended up with cables from monoprice.com for $15.00. After listening close to the Radio Shack cables I decided there was a difference in the sound. It wasn't bad, just different - more high end, less low. I talked to Frank at signal cable and he reccommended a cable for $150. Probably a good cable, but I wanted to keep learning. I eventually learned about monoprice.com. I figured I couldn't lose for $15.00. They sound absolutely great. The lows are are as clear as I've heard them and the mids and the highs blend cleanly.
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • hearingimpared
    edited June 2010
    thor098 wrote: »
    When you called Frank did you tell him you are a member of this forum? He typically gives a 5% discount to us but I think if you would have told him your budjet he may have given you a bigger discount. Plus I believe he has a 30 money back guarantee.:)
  • Face
    Face Posts: 14,340
    edited June 2010
    Ugg...Monoprice interconnects sounded like someone threw a blanket over my speakers.
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    thor098 wrote: »
    I'm using Monoprice for my digital audio cables from my Blu Ray, Cable box and sub-woofer and they all sound great.
  • hearingimpared
    edited June 2010
    Face wrote: »
    I had the same experience but some swear by them.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2010
    The manual for my Benchmark DAC-1 cautions against using unbalanced runs longer than 1,365 feet~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
