Component Racks
Drunkcaballo
Drunkcaballo Posts: 24
edited June 2010 in Electronics
Okay Im sure there is already a thread out there and I searched but couldnt find it.
Im looking for some links for some decent component racks. I need something that is a minimum of 6 shelves, but 7 or 8 would be ideal. Ive got both my HT and 2 Channel running out of the same rack right now, and the DVD player and Satellite tuner have had to move to the floor due to lack of room. Im upgrading the HT amps as well to run either monos or 2 channel + 3-5 channel amplified soon as well, so Ill need to support 3-4 amplifiers and a preamp (or two), so it needs to be built well. If you have a favorite source post away! Id like to find something under $1k, but can entertain racks that are a bit above that if they have some features that are superb.
Thanks in advance.
RTi A7: Front Channels
CSi A6: Center Channel
FXi A6: 4 Surround speakers
JL Audio Fathom 212 Sub
Onkyo 706: Receiver/Pre-Amp
XPA-3: Front Channel Amp
Samsung 50" Plasma: PN50A450
Samsung Blu-Ray
Pre-Amp: Rogue Magnum 99
Amp: B&K Reference 200.2
B&W 805D
DSW Pro 400 Sub
Pro-Ject RPM 1.3 Genie Record Player
Pictures: http://www.polkaudio.com/forums/showcase/view.php?userid=94116
Post edited by Drunkcaballo on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    http://www.hometheaterplus.com/avfurniture-vtiaudvidfur.html
    The great thing about their racks is you can keep adding tiers.
    One warning though, inspect the rack when you receive it and make sure it is perfect. If you wait, you risk VTI Customer Service giving you a hard time.
  • decal
    decal Posts: 3,205
    edited June 2010
    I made this rack using components from a company called 8020,inc.Their aluminum extrusions come in several sizes and you can configure your rack to what your needs are.I used 20x15 butcher block for the shelves.The rack is very solid even with no side supports,the shelves and legs are connected with double bolted brackets and sliding "t-bolts"(also available at 8020,inc.).There are several high end rack designers using this same material.I got an estimate from a rack designer for this layout,he wanted over $900.00,I have less than $300.00 invested in mine!!DIY is very rewarding and saves you a bundle of cash. :)
  • fujicat
    fujicat Posts: 18
    edited June 2010
    I have used this place before. More of networking racks.
    http://www.rackmountsolutions.net/
    SDA SRS, 3.1TL, 2B, SDA CRS, Outlaw Sub
    Carver TMF and SAE amps, Panny projector
  • zingo
    zingo Posts: 11,258
    edited June 2010
    If you are interested in DIY, google the flexy rack. Its a very easy and effective DIY design which I would like to build when I get some cash. Plus, it's adjustable and can easily accomadate any number of shelves.
