Hardware & Ring for mounting your MW Drivers
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2010
    Wow. I see most of TFLF's posts and don't think he's crossed anything up elsewhere...
    ùme neitheir however the nod might have deleted the wrongfull post?
    dorokusai wrote: »
    ....but that's what you folks wanted, lol. I've spoken with him offline, he'll be back and he's fine.
    Nice to hear, great!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • audiobilly
    audiobilly Posts: 351
    edited May 2010
    I sure would like to have a complete set or two of these rings.
    He has now a 15" ring and a 6.5" ring, so what other size would be needed?
    I have a couple of spare 12" PRs, maybe we could get a set made up for each size of the PRs to go with the 6.5" drivers.
  • Conradicles
    Conradicles Posts: 6,365
    edited May 2010
    Put me in line for some of these if you decide to sell them. I want a set for my SDA-1C's.
    Good job Larry!!!
  • Bigbang
    Bigbang Posts: 233
    edited June 2010
    Great idea on the rings. I just got done drilling out my 12" passives and inserting dowels with wood glue to fix them. This is a much more elegant solution. Well done. If you ever offer these, I'd love to have a chance to purchase them.
    Hope your back online soon...
    I like to listen, tinker, listen and repeat.
  • audiobilly
    edited June 2010
  • inspiredsports
    inspiredsports Posts: 5,502
    edited June 2010
    audiobilly wrote: »
    We want TFLF!
    +1 to that!
    Wassup, mods?
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • unc2701
    unc2701 Posts: 3,587
    edited June 2010
    This reminds me of Magico's driver mounting. Can't seem to find the link, but there was an interview with the designer about how every speaker he ever checked had loose screws- by mounting the drivers to aluminum on the other side of the cabinet, it can't pull lose and you maintain the tight, immobile seal. My gallos are the same way- no way they'll pull loose, but anytime you've got screws going into MDF/wood, it'll pull over time.
    Backburner:Krell KAV-300i
  • audiobilly
    edited June 2010
    It crossed my mind, that as well as the crossover plate but there have been no problems with the nut inserts so I left them as is, also where the tweeters are there is a lot of cross bracing around them to make a ring.. if there is ever a problem I will do something...
    But to seal the tweets, you need a good mounting system. I have 2 holes stripped in the tweeters. With rope caulk and good mounting one can seal up these holes as well!
    Come on TFLF!!!!
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2010
    What's TFLF even mean?
  • TECHNOKID
    edited June 2010
    dorokusai wrote: »
    You should know better, TFLF hasn't been away for that long, right? ;)
    DARE TO SOAR:
  • dorokusai
    edited June 2010
    Yeah, it just dawned on me as as I sat on the toilet this morning. He'll be back soon and back in action I'm sure. I have no idea what happened so I can't help you.
  • audiobilly
    edited June 2010
    dorokusai wrote: »
    Here at acronym central?
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited June 2010
    I wish I had access and the know how to use your equipment.
    Gross Joe.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2010
    Man, I'm sticking my foot in it lately ay!
  • hearingimpared
    edited June 2010
    Lasareath wrote: »
    Hopefully it's just your foot!
    Sal
    :eek::eek::eek::eek::eek::eek: You dirty guy you!:D;):p
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    Hmm...Depending on the price, I might be interested in a set of these for my 2A's. I've got a few loose screws in them, and these would work perfectly to give them a solid connection.
    I'd also be interested in some kind of tweeter mounting ring if you come up with something, since I've also got a loose screw in one of my tweeters, IIRC.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • dorokusai
    edited June 2010
