Newb Help Needed
iminurbase
iminurbase Posts: 3
edited May 2010 in Electronics
Hey all, I've been lurking for a while. Would like to pick up a set of speakers and a receiver. I'm not much of a HT guy, but wouldn't mind a receiver that can do at least 5.1 if I want to ever do that. Definitely music is a higher priority. The room the speakers will go is quite shallow, but has a vaulted ceiling. The fact that the hallway to walk to the kitchen is right behind the couch makes surround speakers a little tough right now.
I'm keen on picking up something from Harman Kardon Direct on ebay, mostly because I'm a sucker for the deals to be had on there. Anything you all can recommend here?
Speaker wise I've been waiting forever on Polk Direct for some rtiA3s, but none have turned up in months. Lately I've been pondering the LSi7/9s, but am not sure what receiver I'd need for those. I have an inherited Denon DRA-295 (http://www.usa.denon.com/ProductDetails/587.asp) right now. Most of my listening will be at fairly moderate volumes. I'm not much of a crank it up person.
Post edited by iminurbase on
    edited May 2010
    WELCOME TO CLUB POLK!
    If you're going the AVR route with LSIs you're going to need a receiver that has pre-outs or something like a higher end NAD AVR? Because NO normal AVR can handle the 4 ohm load they present well enough to drive them to satisfying 'musical' levels.
    So get something like a Harman Kardon with pre-outs for a power amp and buy a used amp on audiogon.com 5 channels (200 watts/channel on an 8 ohm load should do you).
    LSis are a great choice for 'music' BTW!
    cnh
  • iminurbase
    iminurbase Posts: 3
    edited May 2010
    Cool thanks. I may wait out a good price on some rtiA3s in the meantime to test the waters.
    I have read of some people having success with higher end AVRs running 4 ohm speakers, but maybe a more basic AVR with a simple amp is a better solution with the LSis.
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2010
    IMHO, look into Onkyo, Pioneer, Denon or Marantz line-up for the receiver, but NOT HK.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2010
    That room deserves a Pioneer SC-25 paired up with a pair of LSi15s bro. A very nice combo and the IcePower Amps can handle the load as confirmed by others.
  • dpowell
    dpowell Posts: 3,081
    edited May 2010
    Sherardp wrote: »
    Motion seconded! :D The Pioneer Elite is an amazing receiver line-up and has great room correction built-in to help with less-than-adequate spaces.
    Welcome to CP where we help you spend your hard-earned cash!
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2010
    You could use in-wall mounted for surrounds....just a thought.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
