MMC6500 vs DB6501
Vital
I currently have db's but got a good deal on MMC (momo) and wanna install them instead of dbs. Nothing is wrong with dbs but momos are a step higher ont he list so maybe i'll get even better sound from them.
According to a bunch of reviews momos are really good in midbass/midrange area but tweeters are just too ruff even when set on minimum.
So did someone here have both of these comps and can gimme a side-to-side comparrision? If not a few more reviews wouln't hurt either
Also, if momo's tweets ARE too ruff can i simply replace them with db? Keep in mind that momo's x-over will be used. Specs for momo and dbs differ a bit:
92db for dbs - 90db for momos
100W for dbs - 125W for momos
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
Kenwood DNX 5140
Post edited by Vital on
I quess i'll just have to install them and see for myself.
Is there a break-in period for mmc6500? Or should i expect them to sound the same as they will the first day or two?2008 Nissan Altima
Kenwood DNX 5140
Polk Audio PA500.4 and PA1200.1 -
DSkip, You wouldn't by any chance be willing to sell those MMC6500 would you?
I would wait and see if you could get some used SR6500's instead - a much greater upgrade.
Pioneer P88RS-II | Polk Audio SR5250 | JL Audio 12w6v2 | 2x Genesis 3 Stereo 100 | Genesis 3 Monoblock
