what should I look to do next?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    cstmar01 wrote: »
    well today I bought this rack
    http://www.audiogon.com/cgi-bin/cls.pl?accsrack&1278270961
    for the price it fit my budget just fine. I'll use it for now just stock and if I find it doesn't work for my 2 channel I'll put in my living room for the HT. This way I have some room to grow and I plan on still getting some better isolation for the TT and the CD player on the rack itself but at least I now have something to work with.
    after this I'll be getting the TT clamp probably for my birthday (june 7th woohoo) and the anti static stuff.
    That's the best part of this post! HEHEHE!!!:eek::D
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2010
    stand didn't work for the 2 channel because the adcom didn't have enough clearance to breathe, soooo even VTI racks only have about .5 inches more clearance. Not sure what I'm going to do because that adcom runs hot and don't really want to have anything close to the top. probably will have to get the VTI rack and an amp stand blah.
  • concealer404
    concealer404 Posts: 7,440
    edited May 2010
    Put the Adcom on the top row, dummy. :p
    And honestly... i think you're being too concerned with the heat aspect, or you play music about 3x as loud as i do. It would get warm in my rack, but not warm to the point that i was worried about it. You saw how crammed it was in there. If it weren't for the fact that my shelves weren't deep enough, i would have been perfectly OK with the breathing room that thing had in my rack.
  • cstmar01
    edited May 2010
    I guess it just scared me. The one day I had some music going for about 3 hours or so and it was pretty warm and warmed up the whole shelf pretty good above it. I just didn't want to kill my baby lol
  • concealer404
    edited May 2010
    Meh. It's a big, bad amp, it's going to happen. :p
    Throw a thermometer in there and see what it reads.
  • cstmar01
    edited May 2010
    that and that thing was a PITA to get in and out of that rack.... good lord get down on your knees, try to take amp out current rack without dings, ok good, then place amp in tighter rack without dings, ok good, now amp doesn't fit like you want, repeat process.....haha
  • concealer404
    edited May 2010
    Yep. My rack looks pretty. That's about all it's good for. It's an utter pain in the **** otherwise. I'm wanting to build one down the road, but i'll have to move out of here, first.
  • hearingimpared
    edited May 2010
    cstmar01 wrote: »
    Is this the VTI rack you are using;
    http://www.audio-video-furniture.com/Common/Product/ImageGallery.aspx?ID=779
    If it is, it fit two Adcom 565 mono's on the bottom with no sweat!!! When I had them, I had them powered up 24 x 7.
  • hearingimpared
    edited May 2010
    DUH!!! Then where does the TT go???:p;) and you're right about over worry on the heat.
  • concealer404
    edited May 2010
    It's strange, everytime i see a VTI rack, my pants don't fit right for a little while. Wish i had room for a two-row rack like that, rather than my stupid tower crap.
  • hearingimpared
    edited May 2010
    cstmar01 wrote: »
    Alright now I'm going to call you a dummy. You place the first platform down, then place the amp, then place the second tier on it points. See easy!
  • cstmar01
    edited May 2010
    well the way the rack went together was upside down so I would then have to hold the amp upside down, place the rails and yeah, that would be even harder lol. :p
  • concealer404
    edited May 2010
    I'm too old to deal with those big black cd thingies. :p
  • hearingimpared
    edited May 2010
    cstmar01 wrote: »
    I didn't realize you had the tower rack! UGH!!
  • hearingimpared
    edited May 2010
    Excuses lame excuses!!!:p
  • cstmar01
    edited May 2010
    thanks guys lol.
    Well I didn't get the VTI rack but I got the 4 shelf and 3 shelf units that I posted the link to on audiogon. I'm using the 4 shelf for 2 channel and the 3 shelf is being used in my HT. I figured that way if I decided to upgrade my 2 channel rack I'll move it into my HT as if I go with an external amp and get a PS3 I'm going to need another one anyways and this way they all match and didn't cost an arm and a leg. 2 racks for 200 bucks can't really go wrong.
  • hearingimpared
    edited May 2010
    Chris are you able to open up the vertical posts and shot load them?
  • cstmar01
    edited May 2010
    yes and no. The way they go together is there is a very slender threaded rod that goes from the top of the rack to the bottom then you slide the larger post over it, then the shelf then another smaller (in length not diameter) post over the rod, ect. You would have to fill each level with shot or sand, and while it could be done would be a huge PITA but I'm sure it would help make the stand more stable ect. I might try it with the 4 shelf that I have for the 2 channel right now. the 3 shelf in the HT I'm not too worried about.
    heiney9 Posts: 25,498
    edited June 2010
    Die spammer
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2010
    Get them 2.3's:)
  • cstmar01
    edited June 2010
    heiney9 wrote: »
    Die spammer
    gee thanks lol :p
    and Lee, I want to, I didn't know if you got my last message about those, I know I could get down to Milwaukee (hopefully as long as work doesn't come up) on the 12th.
