Modding MMG's
Ricardo
By this time they should have been ready, but I've been too busy and not enough time to dedicate to this project. Just following P.Gunn's xover and frame mods.
Thought some might be interested in seeing some pictures (I'm not a woodworker....but I'm learning).
Still work in progress.
http://s159.photobucket.com/albums/t123/garcimol/MMG/?albumview=slideshow
SOPA
SOPA
Post edited by Ricardo on
So far, so good. What's left, grill cloth?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yes, cloth that I've been avoiding because the stapling can be tricky; looking for a good glue...any recommendations? Cloth will go between the frame and an 1/8" masonite shim. Figure that with a good glue I can minimize the amount of staples and reduce the risk of cracking the frame.
Also need to put all the inserts for the brackets/struts/cones, cut the struts and get the cones for the bases._________________________________________________
I've used hot glue before. I'm sure any headliner adhesive type spray glue would work too."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Well it looks like your a wood worker to me, what type of wood did you use??.. Very Nice Job!!!
Looks great Ricardo. -
TOOLFORLIFEFAN wrote: »Well it looks like your a wood worker to me
You say that because you are not looking up close.what type of wood did you use??
Frames are maple, xover boxes are cherry, and bases are oak._________________________________________________
Ricardo-- you have really got involved in that project,,it shows too--
JC approves....he told me so. (F-1 nut) -
Looks pretty sweet! How does it sound with the upgrades?
I don't know yet. Need to finish the mods before listening. Hopefully I will have time to do it soon._________________________________________________
Starting the break in. Maggies can have PLENTY of BASS. I am truly impressed.
Looks good!
Now you can get rid of those silly fish bowls.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
How does the E.T. looking speakers sound and what amp is that in the picture? Nice setup.
An extremely neat project! I'll bet the improvement is very worthwhile. I've never had the chance to hear any "Gunn'ed" Maggie's, but the upgrade seems to be very well liked.
Do you have any other detailed photos of how the driver panel is attached to the main frame? I've been trying to brainstorm some ideas for improving my 1.6's, and that will be part of it.
G~Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
Fantastic work. Congratsengtaz
G~
Other than what's in the slideshow? No....but what's there should be enough....
-1/8" masonite shims; cloth goes between these and the frame, glue and staples. Leave open space for the panel's cross bars.
-Drill through the panel into the frame. Just make sure you don't go all the way through....the paper/tape is to avoid any metal shavings to stick to the panels...remember there's magnets there.
Picture does not show the drilled holes, but you get the idea.
-Screws attach the panel to the frame, through the drilled holes.
You should definitely do the wood frame. Everyone that owns a Maggie should._________________________________________________
I guess you mean the Gallos? They've been here for a whole year. That should tell you how good they souind
The amp is a Pass Labs X250._________________________________________________
Is that sub integrating well with the Maggies?
I haven't tried yet. Just the MMG's for now, and as mentioned I am impressed with the improvement in the bass department. I have two micropro 3000's and will work on integrating them later on. I did have the one in the picture playing with them before the mods, and really liked how they played together._________________________________________________
Thanks for the explanation of the driver panel attachment. Very straightforward. I'm sure it's better than the original staples.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Finally!!!! The finished product. It's been a while, but today I installed the vertical struts. They are not really necessary, but I had them ready so decided to finish the job.
Sounding beautifully. Did I say that all Magnepan owners should replace that MDF frame???
They look great!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
very nice project,Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Thanks Mike. They are sounding even better. The bass is so impressive that I'm running without subwoofers._________________________________________________
awesome, very nice work. Those look gorgeous.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Wow, those look awesome! Great job.--Gary--
Those would go great with a million home installs2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
High marks Ricardo!:cool:
How do you feel about taking over a Lenco plinth project.:D (That's an idler drive turntable).Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »How do you feel about taking over a Lenco plinth project
Huh? Sounds like tight tolerances and very smooth finishing would be required. I hereby pronounce myself as incapable of such things.
Awesome craftsmanship, Ricardo! It'll take me years of practice to create a mortise and tenon joints looking that good.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Thanks. I can't say I'm not proud...but the truth is that with one of those jigs out there anyone can do it after one or two trial cuts. Trust me._________________________________________________
very nice! Look better than stock thats for sure!
