Goodwill find..........SDA-2/II
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited May 2010
    Bobsama wrote: »
    ... On3s's little hack-job, while it'll get the job done, will probably change the cabinet's properties a bit.
    Why, you... :)
    I was definitely only suggesting it as an interim measure. If when you're picking up fuses the Rat Shack or Auto Zone has disconnects that would work it might get you off to the races quicker. In my case, the blade/blade Jones sockets are just attached to a hole drilled part way through the cabinet MDF by a couple of wood screws. My sockets were already busted up so I wasn't risking doing any damage to the speaker that wasn't already done. If the type of connectors you and Bob have don't look like they would be easy to remove and later replace then I retract my recommendation.
    Which brings me to a very important point... If following any advice given by any member of this forum results in damage to the speakers, we will indemnify you only up to the amount paid, and of course we'd have to take possession for salvage. :D
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    Hah. As it happens around here, the speakers parted up are worth more than the whole.
    Just for my own thoughts...
    It'd probably be best to put the female sockets on the cabinets and the male plugs on the cable; the female sockets should have a locking mechanism that may be a bit awkward to use elsewhere. Since most of this would be custom already, we'd have two basic choices on how to wire this. First would be to cross the cable itself; have Wire A go from Pin R1 to Pin L2 and Wire B go from Pin R2 to Pin L1. The second would be to change the wiring inside of one of the cabinets, so that Wire A will go from Pin R1 to L1 and Wire B will go from Pin R2 to L2. That'd probably make more sense to do.
    Then there's the choices on male/female setup. Most consumer XLR cables that I've seen are all M-F; outputs are Male and inputs are Female. So you could have a consumer cable and wire one cabinet as Male and the other as Female or you could use a M-M or a F-F cable with the cabinets wired appropriately. It'd probably be most logical to use a M-M plugs on the cable and have the cabinets both wired with Female sockets.
    Alternatively, there are plenty of other ways to wire this. A TRS 6.3mm jack, either Mono or Stereo would work. Alternatively again, a second set of binding posts and standard speaker wire would also work. The former would probably be a cleaner job but the latter would let you adjust the SDA cable; if your speakers end up 8' apart, a 10' cable should be plenty. There'd be little/no need to have a 30' SDA cable when 20' of it is sitting in a roll on the floor.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • On3s&Z3r0s
    edited May 2010
    Yeah, I'd be a little careful with the crossover cable. The blade/blade interconnect is definitely a straight-through cable. My interpretation of the earliest schematics available is that since the L and R channels reverse the A and B wires to the socket pins the cable should be straight through to the plugs. A continuity test on the stock cable would tell you for sure. Unfortunately, I can't think of another way to be sure without opening the speakers or finding a definitive schematic.
    If it's wrong, it will look like a short circuit to the amp, and depending on the amp's circuitry it will blow a fuse or eventually go into a protection mode until it cools down. I ain't warranting anybody's amplifier against mine or anyone else's advice. :O
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    :p
    I'll figure it out and check myself before I do any mods. <$30 for this mod, so maybe I can even sell my cable to the OP, if (s)he doesn't want to mod his SDA-2's.
  • cov413
    cov413 Posts: 12
    edited May 2010
    On3s&Z3r0s wrote: »
    wow you guys are brutal.....
  • MNmike
    MNmike Posts: 41
    edited May 2010
    [QUOTE=Bobsama;1338928]Yeah, and the original booklet, iirc, called it an "RTA-type connector". Why? No clue. It's similar in size and shape, I think, to the XLR3 plugs. A good mod may be to replace that receptacle with an XLR3 jack and find an XLR3 F/F cable; you'll probably want a 20' cable at least depending on your setup. Since you'll only need 2 wires and are simply using the XLR3 for a standard cable & recepticle, you can use biwire (ie: lamp cord or commercial speaker wire).
    Look at Moon Audio, it'll be $4 per socket and $5 per plug for basic XLR3 connectors, so $18 to do the mod not including the wire. They have some sockets that look like they'll fit with minimal modding. Either way, On3s's little hack-job, while it'll get the job done, will probably change the cabinet's properties a bit.[/QUOTE]
    I think that is the connector for RTA-12's "top-hat" crossover so you can disconnect that from the main speaker cabinet.
    BTW, real nice find.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    cov413 wrote:
    hey you responded to my post about my SDA's I got from goodwill. you mentioned yours have the same interconnect plug mine do. How did you solve the problem, I'm going to radio shack tomorrow to try and come up with a fix.
    You need a pair of XLR3 jacks and a pair of XLR3 plugs. While you're there (if you don't have it already), pick up at a roll of #16 gauge or thicker copper-core bi-wire.
    What you need to be aware of is that the SDA cable is NOT a low-power signal cable; it'll be carrying a significant amount of power and using the SDA effect effectively doubles your power draw on each channel. So, we shan't disregard the wires used or the quality of the connection; a spotty job soldering or otherwise securing the wire to the XLR3 jacks and plugs will be bad.
    A Radio Shack brand XLR3 jack should work fine. You will need four pieces in total. Two for the wire, two for the cabinets. I'd suggest you go with Female receptacles on the cabinet and Male plugs for the wire; it'll make doing the wire a touch easier and will put the lock on the cabinets. In my experiences, having the lock on the equipment is more secure and less prone to failure than having it on the cables.
    The short walkthrough for this...
    1) Lay both loudspeakers on their sides on the ground or on a workbench/table. Remove the 12" passive radiators.
    2) Take note of the crossovers; find the leads going to the Dimensional PCB and then follow them to the SDA receptacles. One side is Pin #1 (Output), the other is Pin #2 (Input). I don't know how to verify which is which, though I'll be finding out tomorrow, hopefully, via email.
    3) Note that XLR3 Pin 1 is "irrelevant"; it's typically a grounding pin and should be treated as such. XLR3 Pin 2 is usually Output and Pin 3 is usually Return. Now, on the RIGHT cabinet, you'll move Pin #1 to XLR-Pin 2 and Pin #2 to XLR-Pin 3. So, remove the current receptacle and rewire each lead to the appropriate place on the XLR receptacle.
    4) Take note again of the LEFT cabinet. This time, however, you'll want to connect Pin #1 to XLR-Pin 3 and you'll want to have Pin #2 connected to XLR-Pin 2.
    5) With Mortite or a similar non-drip sealer, make a ring around both of the receptacles outer edges. You'll want to screw both in (after opening the hole, if necessary) with the Mortite acting as a gasket. Let the Mortite settle for a few minutes and then return to tighten the screws again.
    6) Wire the XLR connectors. If you have or have plans to use a standard XLR cable, you'll want to use triwire here (you can probably pick some up at Radio Shack, though YMMV on finding it). Otherwise, biwire or regular speaker wire will work fine. Wire Pin 2 to Pin 2, Pin 3 to Pin 3. And if you want to use it as a standard cable, also wire Pin 1 to Pin 1.
    7) Test it carefully. Start at low volumes; we don't want to overvolt AND overamp the speakers. You want to check that the Left channel audio is playing on the inner drivers of the left cabinet and the outer drivers of the right cabinet. The inner drivers are the Stereo drivers and the outer drivers are the Dimensional drivers. So long as you have it correct, the one channel will play at full volume on one channel and will sound funny on the other channel. Verify with both sides that it's working properly before you turn the volume up. You'll once again want to test it to ensure it works properly.
    Remember, this is how the loudspeakers should be setup...
    Alternatively, you could wait a few weeks. I'll probably do this mod on my SDA-1's and I'll be able to sell you the cable you need.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    By the way, here are some alternatives I've thought up for you.
    1) Instead of using an XLR3 plugs & receptacles, you could use a second set of binding posts. These SDA's use both wires for the SDA effect (unlike the SDA-1C's).
    2) You could use a TRS 6.3mm jack, either Mono or Stereo. My only concern in that case is accidental removal while in operationg; you'd probably want locking receptacles (Neutrik manufactures some).
    3) You may be able to get both receptacle and cable from Polk directly, at least if you upgrade to Pin/Blade or Blade/Blade.
    Remember, this cable isn't like an RCA cable; it'll be carrying quite a lot of power. Using the SDA effect will double the power draw. The reason I particularly like the idea of using XLR3 as a replacement for the proprietary SDA cables is because it's very safe; none of the pins will contact so the worst that can happen is the a dead cable. Using TRS may end up linking both Output lines which may cause problems. Speaker wire is probably my 2nd favorite solution, but takes up more space and may be more difficult to mount than a small receptacle in each cabinet.
    May someone read over my prior "guide" and just double-check it?
  • cov413
    cov413 Posts: 12
    edited May 2010
    Bob thanks for taking the time to explain. You memtioned waiting a few weeks and buying yours.............is it the oringial cable or one you have made. either way I am be interested if its a straight plug and play and I don't have to make any mods. Really don't have time to mess with these right know, just want to enjoy them the way they should be. Upgrades down the road..............
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    It's the original cable; an ugly grey vinyl thing :p with the appropriate RTA-12 style connector. I've used it for the past ~year now and I'm sure the previous owner used it a lot. For you, it'd be straight plug-and-play... no mods needed to get the SDA effect working. I'll be going back home in a week and I figure it'll be another week until I finish up modding my loudspeakers. PM me and we'll figure out a price and shipping. Odds are it'll be a USPS flat-rate box. I don't know how long the cable itself is; I've got my speakers laid out about 8' apart, but if I had to guess I'd say about 25-30' of cable.
  • cov413
    cov413 Posts: 12
    edited May 2010
    I found a Sansui AU-417 amp and TU-417 tuner for sale near me. Below are what specs I could find on this amp. Question is it only lists output at 8 ohms, I was told that using the interconnect cable drops the ohms down to 2. Is that true and does anyone know if this amp will properly power my speakers.
    http://www.classicaudio.com/value/san/AU417.html
    help please.........................
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    cov413 wrote: »
    As of yet I've never had a problem running my SDA's on 8-ohm taps. I'd recommend, though, that you look for a preamp & a poweramp if at all possible. In my (limited) experience, even inexpensive pre&poweramps have a lot less noise than a similar-costing integrated amp or a receiver.
  • On3s&amp;Z3r0s
    On3s&amp;Z3r0s Posts: 1,013
    edited May 2010
    cov413 wrote: »
    Googled a bit and found this: http://www.audiokarma.org/forums/archive/index.php/t-29821.html
    "in know for a fact that you cant drive a pair of 4 ohm speakers without clipping with the au-417. had to bring the infinity speakers back to the store and get some cerwin vegas..."
    Doesn't bode well. Find out as much as you can about any amp you consider and see what kind of power it can put into a 4 ohm load. (I wouldn't worry too much about the 2 ohms, the SDA's might dip to 2 ohms, but I'd be really, really suprised if they were designed to be a 2 ohm average load with the interconnect cable).
    Some amps designed only for 8+ ohms can't handle 4 average without overheating or clipping. But, some amps actually increase their power into a 4 ohm load either by automatically detecting the lower impedance or having a switch somewhere on the amp. The first amp I tried with my SDA 2's was a NAD 2100. It's rated at just 50wpc into 8 ohms continuous, but according to NAD could put 250w into 4 ohms for short bursts. It worked, never audibly clipped, but the bass was thin.
    I tried a 105 wpc Hafler 9180 and that was very respectable. I'm running a 200 wpc amp now and I really like the sound. For better or worse, the SDA's like power. Whatever amp you get, if you hear it start to clip, turn it down. (NAD amps also have a "soft clipping" feature where the amp will sense when it's being overdriven and turn itself down to try to avoid damaging the speakers.)
    Did you ever figure out if all your tweeters are working?
  • smcgov34
    smcgov34 Posts: 46
    edited May 2010
    I've been looking for some of these for a year, but they're always gone on CL within an hour or so around here.....never in a million years would I find them at SA...and if I did..around here they'd probably be like 200 bux..
    I'm jealous
  • On3s&amp;Z3r0s
    edited May 2010
    Just for Bob :) I fixed my hack job with the proper jones socket for the blade / blade interconnect. These things are pretty damn simple to work with, so if they happen to fit in the hole that's already drilled in the cabinet for the not-quite-XLR connection then I'd say they're a pretty good way to go. I don't have a caliper or I'd give the exact diameter of the socket. The socket body is very close to 9/16 inches in diameter. There's a little pin that holds the screw bracket to the body that I had to dremel out a notch for. Otherwise just a very quick and simple solder job and screw it back into the cabinet.
    For the record I couldn't tell any sonic difference between this and the hack.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    Get some mortite in there to seal them up. Tiny changes rarely make an audible difference, but a bunch of small changes may. Now then, I still need to do a continuity check on the SDA cable; I've been busy with other stuff. In other news, I found Mortite-branded cord weatherstripping/loudspeaker sealant at my local Home Despot (that's not a misspelling).
  • On3s&amp;Z3r0s
    edited May 2010
    The mortite's totally unneccesary in this case. The hole for the socket doesn't completely penetrate the cabinet. There is just a very tiny hole only large enough for the two 20ga wires to the socket and those are a tight fit! The speakers pass the PR push test with flying colors. But I do plan on getting some mortite for use when replacing the tweeters so I might come back to these IC sockets if I'm in an overkill kind of mood.
  • kchilaka
    kchilaka Posts: 55
    edited June 2010
    cov413 wrote: »
    Newbie here. I'm a big fan of Polk's but don't know much about the vintage models. A friend of mine found a set of Polk SDA-2/II at a Goodwill store today and gave me a call. I had him snatch these up for me for 25 BUCKS for the set. I have a couple of questions for you experts out their.
    1. What is the purpose of the interconnect cable?
    2. A couple of the fuses were blown. What does this mean, and size are the replacements?
    3. Hooked these up to my Pioneer Elite reciever and with only one tweeter working on each speaker I was still blown away by how full the range was on these. What can I except when all speakers are working properly?
    4. Was thinking of selling these and making a profit but I love the sound and range these speakers have, IF I were to sell how much could I expect to get for the set. They are in surprisingly good condition, no peeling, only a couple very slight scatches, the grills are pretty good could use a recovering perhaps but nothing broken or missing.
    Any input you guys can offer would be great. thanks
    Like the OP, I scored a pair of Minty SDA-2 speakers on CL. Came with the interconnect cable. I think I stole them but who knows what they are worth nowadays. I think they are the original SDA-2. Here is what they look like.
    I tried them out yesterday with my Sony DA30ES receiver and they sound great except the low end wasn't that strong. The speakers do seem to go down low but they don't have the "slam" if you will. Perhaps I am just used to Sub-Sat combos where the sub levels are a tad high. The mids and highs were beautiful and they seems like an articulate pair of speakers.
  • On3s&amp;Z3r0s
    edited June 2010
    kchilaka wrote: »
    Nice work, those are definitely in fantastic shape. The bass is a little underwhelming, but they're wicked good for what you probably paid for them. I overpaid for mine, but I really wanted to hear a pair of SDA's and $300 is the cheapest I've seen a pair go for in my neck of the woods!
    Anyway, welcome to the club and to the mental derangement that is vintage Polk. ;) For kicks, you should post asking whether you should upgrade the tweeters to the modern RD0194 replacements and rebuild the crossovers. Also, you'll now need to start shopping for some SDA-SRS to find the bass that you're missing.
    Sorry, I shouldn't kid. Seriously, I hope you enjoy hearing your music on them. I love mine, they're a great and very interesting speaker.
    PS: I will say one thing about the bass... the SDA 2's are a 4 ohm speaker that will handle 500 watts. It looks like your Sony does 70wpc into 4 ohms stereo. I had mine on a 70wpc NAD receiver and the bass was really poor. I picked up a 105wpc Hafler amp and it improved, but when I put 200wpc into them (with the amp plugged directly into the wall, not a surge protector) the bass just about doubled. Everyone says all the SDA's improve the more power you feed them, and from what I've seen it's definitely true.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    On3s&Z3r0s wrote: »
    You are absolutely right. I had been using a 100 WPC Proton D-1200 to power my SDA 2B's and liked what I heard from that setup, but always had to boost the bass a lot to get what I wanted. Then the upgrade bug hit. Now I'm using a Carver TFM-45 which puts out 375 WPC, and the difference is amazing. These SDA's do like to be fed a healthy diet of power. I'd upgrade the amp to something that puts out at least 250 watts. More if your pocketbook can stand it.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • On3s&amp;Z3r0s
    edited June 2010
    ... These SDA's do like to be fed a healthy diet of power. I'd upgrade the amp to something that puts out at least 250 watts. More if your pocketbook can stand it.
    Come to think of it, my awesome and inexpensive (relative to new) vintage speaker score wasn't so inexpensive since I wound up dropping several hundie more on an amp that could get the most out of them.
    Damn you, Vintage Polk!!! :D:D:D
  • helipilotdoug
    edited June 2010
    On3s&Z3r0s wrote: »
    LOL Yeah, ain't that the truth! :D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • kchilaka
    kchilaka Posts: 55
    edited June 2010
    I was thinking of going the other way on this. I was planning to get a digital panasonic xr55/xr57/xr70 . These little amps have extraordinary accuracy from their digital equibit amps. They also have the ability to biamp and triamp the fronts in stereo mode. I guess I have to see if they have the guts to drive these speakers properly.
    On3s&Z3r0s wrote: »
    Nice work, those are definitely in fantastic [I[/I]shape. The bass is a little underwhelming, but they're wicked good for what you probably paid for them. I overpaid for mine, but I really wanted to hear a pair of SDA's and $300 is the cheapest I've seen a pair go for in my neck of the woods!
  • On3s&amp;Z3r0s
    edited June 2010
    kchilaka wrote: »
    Ahhh... going for something a little more Mazda RX-8 than Dodge Viper? I'd be very curious to hear how you like it with the SDA's. I don't know of any way to bi-amp the SDA2's unfortunately, but it would be interesting to hear how a digital amp would work with them. You might want to check into whether they classify as a "common ground" amp, though. A non-common ground amp could be damaged by the SDA's since the interconnect creates a short between the 2 channels when those channels don't share a common ground.
  • kchilaka
    kchilaka Posts: 55
    edited June 2010
    On3s&Z3r0s wrote: »
    I like your analogy :) Yup RX8 over a viper. About bi-amping the SDA.. Surely you meant that there isn't a way to bi-wire the SDA. As for bi-amping, the pannys handle the bi-amping logic internally. Yeah. I do think that most modern day receivers are common-ground but I guess I better watch for some smoke when I hook them up next week.
  • gdb
    gdb Posts: 6,012
    edited June 2010
    kchilaka wrote: »
    Biamping SDAs requires that the neg. speaker term. be connected from one amp to the other or, later models could use a special AI-1 interconn. cable with a transformer in the sig. path. I'd make damn sure about the dig. Panasonics before I hooked anything up if I were you.(which of course,I am not.) Good luck!:)
  • On3s&amp;Z3r0s
    edited June 2010
    kchilaka wrote: »
    Ah... cool. I have to admit I'm pretty unfamiliar with the those amps. I have a Pioneer multi-channel amp, and it supports bi-amping but only by using the rear surround channels' speaker binding posts. So, on the Pio you can't bi-amp without also bi-wiring. Pretty sweet if the Panny's can just route the additional power though the one set of binding posts. I'm definitely going to have to take a closer look at those!
  • donberry
    donberry Posts: 7
    edited July 2010
    hello there, well the original poster went for the profit and sold them to me for a chinese sks rifle and $100.00. While the speaker is in nice condition, I think he got a little emotional when he said they were near mint. The veneer on the top edges is a tad crinkly - nothing that distracts from their looks, but not near mint.
    I told myself I was done buying any new gear unless it advanced my main stereo, but these intrigued me due to the SDA. I have not had the time to sit down and listen to them critically yet, just made a quick interconnect cable and fortunately where I am testing them is a long flat wall.
    As I plan on making a cable, I just went ahead and soldered the wire on temporarily so I could hear them.
    Again, have not listened critically yet, 1st impression is echoey. They are flat against the wall, maybe 3" from it, but there is a big "entertainment" cabinet between them, which probably accounts for it being echoey. I have the fronts of them even with the front of the cabinet, hoping that since it was all front firing, it might work out okay - will still have to play around with them.
    They do seem good enough top go ahead and upgrade the caps after I search around here and find the schematics. I am hoping that the crossover is just behind the binding post plate ?
    I will probably use Dynamicap and Sonicap, depending on the values I need.
    I plan on making a better IC cable over the weekend so I can hear the difference with it and without it.
    Biggest disappointment to me was the veneer. I was thinking this was near the totl for Polk at the time. I would have thought they would have used a nice wood veneer. The plus side is they match the furniture in the family room so the wife doesn't mind them.
    Currently driving them with a Carver TFM-35 amp, will probably just keep using that. I am using a marantz 2250 as the pre.
    Will be interesting to put these thru the paces as I have never had a pair of Polk speakers before.
    The OP made a nice tidy profit and I feel I got a good deal to, so everyone seems to be happy - I never used that rifle anyway......:D
  • donberry
    donberry Posts: 7
    edited July 2010
    guess I know why it is echoey - one of the tweeters does not work, it is the one when NOT using SDA. I disconnected the IC, so will have to check out the other tweeter. I know about the tweeter upgrade, for now would just like to use the original so I am going to keep an eye peeled out for that
