What's Your Favorite Center Channel
  • Jazzdrummer
    Jazzdrummer Posts: 11
    edited May 2010
  • B.Meek
    B.Meek Posts: 8
    edited May 2010
    mystik610's assertion that the center should have the same drivers as the mains leads me to ask which Polk centers use the same as the Polk RC65i in-wall speakers?
    I would like to mount a center speaker above or below my HDTV (which is on a swivel-mount).
    Thanks,
    -- brian
  • maandjojo
    maandjojo Posts: 293
    edited May 2010
    Phantom.
    Joe
    Joe
  • domflane
    domflane Posts: 653
    edited May 2010
    My CsiA6, hands down
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • 20hz
    20hz Posts: 636
    edited June 2010
    I still got that polk cs300 I havent a place for it , it will probebly go on ebay .
    It sounds beyond awesome (old polk rules) .
  • Snowdogyyz
    Snowdogyyz Posts: 37
    edited June 2010
    CSiA6. I have the CSi5 as well. Both are excellent center channels for my needs.
    Denon 4311CI
    Emotiva XPA-3
    Oppo BDP-83
    Polk RTiA7 fronts
    Polk CSiA6 center
    Polk FXiA6 surrounds
    Polk PSW505 sub
    Harman Kardon HK3490
    Monitor 70
  • cdn5003
    cdn5003 Posts: 144
    edited June 2010
    My favorite is the Csi A6. It is the most accurate center I have heard. I have experience with Csi25, CS2, Csi A4. The tweeters in the A4 and A6 are more accurate for movies. The A6 dominates the A4 though in output, especially with deep male vocals.
    The CS2 is good for its price point, offering as much output as the A6 but less clarity. The Csi25 can't keep up in a large HT.
    I would advise using a phantom center if you are building a HT piece by piece and start off with a nice pair of towers. Save money until you can get a large center that will really deliver.
    HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
    2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
  • love2listen
    love2listen Posts: 172
    edited June 2010
    I'm currently using a Lsi9 which replaced the LsiC and I must say, that for my ears, the Lsi9 does a much better job than the LsiC.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2010
    This is a tough question to answer on such a broad scale... the rest of your system will largely affect what center sounds good with it.
    For me, the best center I've ever owned was the Ascend Acoustics CMT-340. This was before they released their "SE"s. It blended very well with the matching towers and 170 rears, and produced a very full sound. In fact, that may have been my favorite Surround Sound setup I've ever owned!
  • newsman
    newsman Posts: 203
    edited June 2010
    I'm curious about your assertion, because after moving from RTi series to LSi, the center channel in LSi series was the only regret I have over the RTi C400i speaker. In what whey you like LSi 9 more and have you tried both bookshelves together or does it create some sort of phase or load issues? My main feeling is that LSi C is underpowered and lower mid range heavy compared to LSi15 - but it might be intentional for the deeper monologue.
  • kevhed72
    kevhed72 Posts: 5,139
    edited June 2010
    I just bi-amp'ed my CSiA6 with 2 pairs of MIT EXPS1's, which used to run my front speakers. Took the cheesy brass jumpers off, and ran the pair to an Adcom 545ii. To hook the amp to the avr, I used a pair of Blue Jeans Belden ICs and a Radio Shack RCA plug splitter off the single center channel output.
    Now considering the IC's and splitter are the weak link in this equation, I was quite impressed with the improvement in both detail and clarity of the center.
    Last night I demo'ed parts of the 2nd Star Wars flick and the hockey game, and couldn't be happier. The improvement I noticed was in bi-amping vs. just running a single channel and using the brass jumpers. I'm going to do some more comparisons this weekend, but so far so good...
  • mantis
    mantis Posts: 17,349
    edited June 2010
    The one that matches the given speaker package I'm working with.
    Dan
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2010
    I just had a listen to the martin logan stage yesterday ............ Now that probably is the best centre channel out there for accurate sound reproduction ........ but for $3000 I think I will pass
  • love2listen
    edited June 2010
    newsman,
    The biggest difference I noticed when I replaced the LsiC with the Lsi9 was the cohesion of the front sound stage. The Lsi9 seems to tighten up the and bring together the front three better than the LsiC, at least to my ears! One other aspect I prefer of the 9 over the C, is the overall sound of the vocals. With the 9 the vocals sound more natural, whereas with the C, sometimes the sound was too muffled for my taste. I know there are a few memebers that have had their LsiC XO's moddified and have been very pleased with the result. At some point I plan on experimenting with 2 Lsi9's as centers and also bi-amping to see if there noticable difference. Hope this helps! :)
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2010
    I still remember the night I swapped out my old Yamaha center with the CSi5. My face literally lit up when hearing the difference.
  • olds97_lss
    olds97_lss Posts: 22
    edited June 2010
    Probably shouldn't even post this, but I recently picked up a polk center. I was planning on buying something with at least 6" drivers in it to give me more mid-range, the CS20. But, after listening to the CS20 compared to others, there wasn't much of a comparison to the CSi A4 and CSi A6. I bought the A4 since it was more affordable and compared to the JBL CS25 I had, night and day difference with general sound quality. I had no idea how muddy sounding the JBL was.
    Now I'm on the hunt for better front bookshelves and rears to better match the A4. The JBL's I have are ok (E20's and E10's), but if the difference is as great as the center was... I'll be selling what I have on ebay soon I'm sure.
    Since I live in an apartment, quantity of sound isn't as large a concern as quality of sound.
    I had tried the bose center and it was just aweful. Thoughts of "headphones in a soup can" come to mind... That's what I replaced with the JBL and it got me by for 6 years or so, if not longer.
  • bsturgeon89
    bsturgeon89 Posts: 128
    edited June 2010
    Sunfire CRS-3C .
    I like mine a lot because it can handle a lot and still sound fabulous in the process
  • yepimonfire
    yepimonfire Posts: 256
    edited June 2010
    any ones that are as loud and authoritative as a large bookshelf or floor speaker, polk sells a center with 6.5" drivers, this thing is a beast.
  • scoobygt68
    scoobygt68 Posts: 19
    edited June 2010
    Paradigm Sig C5 v3
    Fronts: Paradigm Signature S8 v3
    Center: Paradigm Signature C5 v3
    Rears: Paradigm Studio 100 v2
    Surrounds: Paradigm Studio 100 v2
    Sub: Def Tech Trinity
    Display: Epson 8500 UB on 120" screen
    Processor: Yamaha rx-v3800
    Amp: Emotiva XPA-5
    Xbox 360
    PS3
  • bradkara124
    bradkara124 Posts: 1
    edited June 2010
    I like my LSi C its awesome !
    My Home Theater Project June 29 2010
    Panasonic Viera TC-P65VT25
    OPPO BDP-83 Special Edition Blu-ray Player
    Cin
