What's Your Favorite Center Channel
loragland
loragland Posts: 15
edited June 2010 in Speakers
What's the best center channel you have owned? I currently have a Csi 40 as my center. It has been a faithful anchor to my home theater, but I am wondering upon completing my new theater room if there is a center channel that would better suit a larger crowd. Dialogue can sometimes get barried even when all speakers are properly calibrated. Maybe my room acoustics are affecting my sound right now, in fact I'm sure of it...but I was just wondering if either the Csi 5 or some other center channel may be a better choice for feeding a larger room. Thanks fellas
Fronts: Rti 150s
Center: CSi 40
Side Surr: Rti 55
Surr. Back: Csi 30
Sub: SVS PB12 Plus/2
Receiver: Denon 3802
Conditioner: Monster HTS 3500
Post edited by loragland on
    VR3 Posts: 29,427
    edited May 2007
    I have not found a single center channel I felt was worth its asking price.
    Infact, I think center channels are the absolute worst value in Home Audio in every way. They all suck equally. No matter the price point.
    I think a pair of bookshelfs work better for the center channel job. Same price, and you can use them for something else if need be.
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Monitor 5 not M5jr
    engtaz
  • MikeC78
    MikeC78 Posts: 2,315
    edited May 2007
    A phantom center.
  • Gaara
    Gaara Posts: 2,415
    edited May 2007
    Wow I thought I was going to be the oddball, phantom center is the best center I have ever heard as well.
    Jared
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    Phantom channels are great until you are sitting off center..or have guests.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited May 2007
    I have read this before but I don't fully understand what a "phantom" center is. I am curious as with my smaller room and now with the Usher's it may be a better choice for me vx. the LsiC.
    Thanks,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Gaara
    Gaara Posts: 2,415
    edited May 2007
    Mike,
    A phantom center is when the center channel information is sent to the left and right speaker in mono and therefore it sounds as it is coming from exactly between them. I never liked centers much because with my setup the center was always 1.5-2ft above the main speakers and sounds just didn't sound right.
    The benefits of a phantom center is you save money on the center and sometimes can save money by not having to spend the extra money on an amp to power the center. You use your 2ch speakers and amp instead which in most cases will be nicer then the center speakers, and therefore you get better sound quality. You also don't have issues matching the center to the L/R as the L/R are the center. This means that tonally there is no change panning across the front soundstage, and there is no sudden change in height. In my case my tweeters are about the center of the TV, so the center channel being played by my L/R speakers plays exactly in the middle left and right and top and bottom of the set, much more natural then coming from above the set.
    The downside of a phantom center is mainly that you have to be exactly in the middle to have it work. If you are off the left or right with a mono sound being played by both speakers your ears will think the sound is coming from the speaker closer to you. If you are a little left or right then the sound pulls in that direction, and therefore it sounds like the center channel is a little to the left or right of the set. If you are far right or left, like right in front of the speakers, your brain will think the sound is coming just from that speaker, and will ignore the other (Hass Effect?). Another downside is that with a dedicated center most of the vocals are played through it. The sound may get congested with the L/R doing double duty. This also generally eliminates the ability to pump up the center channel with soundtracks that you can't really hear what they are saying.
    I think that about covers it.
    Jared
  • Midnite Mick
    edited May 2007
    How is this set up via the processor? Is it simply a matter of removing the center from the speaker setup and the processor will automatically take care of everything?
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • Gaara
    Gaara Posts: 2,415
    edited May 2007
    Mike,
    From my experience it was that simple, just set center to no and you are all set. I would imagine your pre would describe the process, or if you have a test disc like avia you could try it and use the test disc to make sure the center channel is being played by the L/R speakers.
    I use a phantom center with my Gallos, I used a LSiC like you have for a short while, but much preferred the phantom center. I will admit it takes a little getting used to, it does sound very different then what I was used to.
    Jared
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2007
    Cs300
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Damn, Sid, them is some strong words.
    Gotta admit, though, you have a point. After going through about 10 or more center channels over the past few years, I settled on a pair of bookshelf speakers. Better clarity and wider soundstage. They don't necessarily need to be timbre matched, but calibration is essential. The secret is to place both of them next to one another at ear level.
    "God grooves with tubes."
  • louthewiz
    louthewiz Posts: 581
    edited May 2007
    Cs400
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • 20hz
    20hz Posts: 636
    edited May 2010
    it took me a year to find something .
    I got a Kef 90 , the off axis response is great (you dont have to angle it ) .
    The voices being from the dead center is best , (not from a few speakers) .
    I A/B compared it to a polk cs300 , the cs300 sounds incredable on the verge of amazing . but off axis (stand no straight in front) I heard a deley coming from the other 5.25" and aiming seams to be a concern if you want the best sould from the polk .
    If I did not allready have the polk monitors as satalittes I would use 2 cs300's , its a amazing speaker .
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2010
    Cs350
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • mantis
    mantis Posts: 17,378
    edited May 2010
    There are many good quality center channels.
    Rule is to match what ever speakers you have. With proper calibration and placement , most center channel perform well. Whats funny is I read all these other threads on how people are not happy with there center channel speakers , I have set up so many different center channels I couldn't even tell you a general number. never once did I feel the center channel that was correctly matched to the given system I was working on didn't do it's job.
    Dan
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited May 2010
    Martin logan motif and polk csi5
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2010
    Using the same exact speaker as my left and right mains is working well for me. I realize not everyone has the space for a tower center, but it sure does create a seamless front soundstage. :)
    Edit: Why have we resurrected a 2-yr-old thread for this??
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2010
    Bigger is alway better IMHO.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • warren
    warren Posts: 756
    edited May 2010
    Csi 5
    Mirage OS3-CC
    Polk Rm 202
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited May 2010
    CSi A6
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • mystik610
    mystik610 Posts: 699
    edited May 2010
    Early B. wrote: »
    Screen should be at eye level, tweeters should be at ear level.
    Easier said than done unless you have an acoustically transparent projector screen.....in which case using an identical third tower as a center channel would be the absolute best option.
    The whole purpose of a center channel is to keep the dialogue affixed to the center of the screen no matter how far off axis you're sitting. If the only seating positions in your listening area are smack dab in the middle of your L/R's (the L/R's are an equivalent distance from the listening position, forming an equilateral triangle) then a phantom center would work....but really in any room with more than one listening position, this is less than ideal. If you're sitting even slightly off axis, the center channel dialogue will favor the speaker you're sitting closer to, and the sound-stage will fall apart in my experience. The dynamic range of your L/R's will also be affected, as they'll be tasked to convey two channels of information.
    The construction of a center channel is less than perfect acoustically, but is the best solution for 98% of people out there....unless you enjoy watching movies by yourself and have on solitary listening position perfectly centered in the room, or if you're on of the very few who have an acoustically transparent screen.
    As far as the 'best' center channel....I think that largely depends on what you're using as your mains. You want a center channel that shares the exact same drivers as your towers, as this will make the front sound-stage blend seamlessly. A third tower identical tower is the best option if that's feasible. If you can fit a bookshelf or a pair of bookshelf speakers that would work too....some people like laying a bookshelf horizontally...ruins imaging in my experience, but others like it.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • vmaxer
    vmaxer Posts: 5,120
    edited May 2010
    I use a CS1000P and love it, I also have used a CS400i that did very good. I guess it depends a lot on the rest of the speakers used.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • kevhed72
    kevhed72 Posts: 5,142
    edited May 2010
    CSiA6 with a dedicated amp powering. Right now I am using only one channel of the amp, but I am going to try bi-wiring the center eventually.
    (on a side note I found most TV stands/cabinets do not have good center speaker placement built into the design unless you want to spend $$$$)
  • bsoko2
    bsoko2 Posts: 1,449
    edited May 2010
    My mains are 2.3 TL's and the center is a Aperion Intimus 6c. Blends with mains real well and has a nice SQ.
  • nhhiep
    nhhiep Posts: 877
    edited May 2010
    it depends on your L/R speakers, but since I have Rti8s. my favorite is CSi5. this thing is pretty loud and clear. it's pretty much a Rti8 in a smaller box. Center with 2 6.5" speakers is as big as they can get, until you move up to some DefTech with a sub built-in
  • renowilliams
    renowilliams Posts: 920
    edited May 2010
    loragland wrote: »
    I have the same center channel and I have been very pleased with it.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • Drunkcaballo
    Drunkcaballo Posts: 24
    edited May 2010
    kevhed72 wrote: »
    I have never used another center than the CSiA6, but kevhead is right about running a dedicated amp. When my B&K got here I hooked up my fronts to that and the center was left on my XPA-3 by itself. Wow what a difference. I know everybody on here loves Emotiva's but the next upgrade Im doing is getting rid of mine or retiring it to surround duty. They dont have the beans to get the RTi's to their potential...well at least not the multichannel Emotiva's...unless its dedicated to one speaker.
    RTi A7: Front Channels
    CSi A6: Center Channel
    FXi A6: 4 Surround speakers
    JL Audio Fathom 212 Sub
    Onkyo 706: Receiver/Pre-Amp
    XPA-3: Front Channel Amp
    Samsung 50" Plasma: PN50A450
    Samsung Blu-Ray
    Pre-Amp: Rogue Magnum 99
    Amp: B&K Reference 200.2
    B&W 805D
    DSW Pro 400 Sub
    Pro-Ject RPM 1.3 Genie Record Player
    Pictures: http://www.polkaudio.com/forums/showcase/view.php?userid=94116
    Tony M Posts: 11,617
    edited May 2010
    All of Polks centers that I've owned or still do are really high quality to me. The CS400 is one I've heard and liked ALOT.
    But I did like a Paradigm cc-370 I owned for a few years. That thing was realy nice. I still own a Paradigm cc-170 that is really nice to.
    I've owned a Klipsch giant center that was all you could want in one also.
    But the best has been that Paradigm cc-370 for me.
  • Bernal
    Bernal Posts: 991
    edited May 2010
    POLKAUDIO LSiC
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's
    03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
    04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    05) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    06) HITACHI P55T501. 55" HD1080 Plasma HDTV
    07) POLKAUDIO LSiC (Center speaker)
    08) POLKAUDIO LSi15 LEFT (Front speaker)
    09) POLKAUDIO LSi15 RIGHT (Front speaker)
    10) POLKAUDIO LSiC Vertically (Surround speaker)
    11) POLKAUDIO LSiC Vertically (Surround speaker)
    12) POLKAUDIO LSif/x LEFT (Surround back speakers)
    13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
    14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
    http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated)
  • playback
    playback Posts: 101
    edited May 2010
    Boston Acoustics VR-12 9yrs and still the best I've heard.
