The Adcom GDA 600 modification thread
It has to be a ground issue, check and recheck. If all else fails maybe check for a cracked PCB.........it's a long shot but it is sort of fragile since it has to support both transformers. Also if you have a magnifier check you solder joints to make sure there isn't a slight "bridge" across the terminals, some of those smaller caps have almost no space between them.
Good luck
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
The gain after power supply capacitor changes was with the old OP amps in. With the old listening level at about 10 oclock on the volume knob I found i had to lower it to about 8:30. Its entirely possible that this wasn't a gain so much as the old supply caps were damping loud transients... definitely had a sense of greater dynamics but no hum. Hum is in both channels after step 2, very audible at about 11 oclock on the volume setting. Will check washers, these were between screw heads and PCB. For the power caps, I have these soldered to 4 & 8 on the backside of the PCB OP amp holder, 18awg wire soldered to cap ground leads , the wires twisted and attached to chassis ground screw. Will check capacitors for bridging. Really curious to see how this turns out as before I saw the thread I was contemplating buying a DLink III DAC... had a good experience with the Musical Concepts Hafler mod so wanted to give this a shot. My soldering skill isn't the greatest but on the audio board the bad OP Amp forced me to look at every solder with NTF. Will recheck the power supply board and post any learnings.
Modified AR Turntable with Grado Platinum
Adcom GDA600 DAC (in transition)
Linnn Genki CD Player
Conrad Johnson PV-10 preamp
Signature Mod Hafler DH-200 amp
Magnepan 1B original owner (waiting for my 1.7 ship to come in) -
For the power caps, I have these soldered to 4 & 8 on the backside of the PCB OP amp holder, 18awg wire soldered to cap ground leads , the wires twisted and attached to chassis ground screw.Will recheck the power supply board
still continuing to work this.
1) recieved new OP Amp, it played wonderfully for 3 seconds then died so it appears to be a fluke that I have 1 channel working... I had swapped it with the working OP amp
2) tried redoing the caps between pin 4& 8, then removed them, no real difference although bass may be better without.. hard to judge
3) problem appears to create a feedback loop between preamp and DAC as moving preamp volume knob creates static transient that occurs with no other input source.
4) same problem exists with optical and analog inputs, hum only exists with signal input
I have some Cardas solder on order, used Radio shack brand to start with, will desolder and solder all with new solder.
Also noted that on the power supply board near the off/on button one of the factory components marked on the board as a resistor instead has a capacitor. Will post picture later, curious if everone elses board has the same change. -
3) problem appears to create a feedback loop between preamp and DAC as moving preamp volume knob creates static transient that occurs with no other input source.4) same problem exists with optical and analog inputs, hum only exists with signal inputWill post picture later, curious if everone elses board has the same change.
What can I do to help guys? Am I right in understanding that it's destroying the op-amps?JC approves....he told me so. (F-1 nut)
george daniel wrote: »What can I do to help guys?Am I right in understanding thats it's destroying the opamps?
A picture would help greatly--keep us posted.JC approves....he told me so. (F-1 nut) -
I see Parts Connexion has the Burson series 1 voltage reg's on sale.For those wanting to squeeze a bit more out their GDA600,IMO these discrete regulators feeding the OPA627's should take it to the next level.Burson 72017 and 72019 are the suitable replacements for U100 and U104 on the PS board.
http://www.partsconnexion.com/regulator_burson.html
http://www.partsconnexion.com/t/Index/burson_reg.php -
so the 72017 pops in U 100 and the 72019 pops in U 104?
Thats is? Hmmmm,JC approves....he told me so. (F-1 nut) -
Interesting............If you try it first George I'll give it a shot. Can't imagine it getting better"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
If Fred will give me a "paint by the numbers" I'll order them today.:)JC approves....he told me so. (F-1 nut) -
OK-- I think that i understand this-- I'm gonna order them and I'll report back here,,,one thing,,for Mr. Fred-- do I remove the reservour" cap that I added to the op amps?JC approves....he told me so. (F-1 nut)
george daniel wrote: »so the 72017 pops in U 100 and the 72019p pops in U 104?Thats it? Hmmmm,george daniel wrote: »,one thing,,for Fred-- do I remove the reservour" cap that I added to the op amps?george daniel wrote: »If Fred will give me a "paint by the numbers" I'll order them today.:)
OK -- onward we go to Phase II --stay tuned;)JC approves....he told me so. (F-1 nut)
george daniel wrote: »OK -- onward we go to Phase II
george daniel wrote: »OK -- onward we go to Phase II --stay tuned;)
Awaiting Phase II and the directions .
George at first I was a little disappointed in this mod because it was really analytical and hyper detailed. But, I have to say after about 200 hours break-in this thing is phenomenal. Same detail but it's soooooooo smooth.
Detail in spades, great extension and the decay and air around instruments is superb. Vocals are just unbelievable. I also find that the DAC needs about 30 minutes of warm up for it to sound good.
Wait til you get to phase 4,thats when it really begins to shine.;):D
Hey,, I gotta' survive the second phase first,lol and H9 nailed it--ohhh,, so smooth,,yessir,detailed too,,ya'll hear what the man said?;)JC approves....he told me so. (F-1 nut) -
Damn, damn, damn, you guys are killing me here.
George, Fred, Ben or anyone feeling like doing this to mine for a couple bucks?
DaveOnce again we meet at last. -
Ok pictures attached and some more data
R113 on the power supply board has a capacitor instead of a resistor
Pins 4 and 8 measure -21/+21 V vs the -15/+15 mentioned above -
Dave
I'll do it if you are not in a hurry,,I do this for fun/hobby,so it won't be a quickie.:)JC approves....he told me so. (F-1 nut) -
R113 on the power supply board has a capacitor instead of a resistorPins 4 and 8 measure -21/+21 V vs the -15/+15 mentioned above
If you look at the pics I posted as Fred states there should be a resistor at R113. Wow!"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Dave -
I would gladly do it for you Dave but looks like George has you covered.Also shipping might be a pain.
Fred--I'll definately defer to you,,as your expertise far surpasses mine--take him up on it Dave:)JC approves....he told me so. (F-1 nut) -
george daniel wrote: »Fred--I'll definately defer to you,,as your expertise far surpasses mine--take him up on it Dave:)
Whatever you guys decide is fine with me,I'll be happy to help folks with any upgrades. Let me knowJC approves....he told me so. (F-1 nut)
Im happy to be helped, haha.
Whichever of you fine gentlemen, I would be grateful. Due to logistics, George you would probably be best option, Pm inc.
Thank you Fred for the offer, as always, you rock.
Guys just remember,when attempting this mod,, "never get out of the boat";)
Edit; stay close to the original plan,is what the above statement means.JC approves....he told me so. (F-1 nut)
