Can I do a mono block with a rotel RB-1080
Tomasito
Tomasito Posts: 142
Hello,
I have the opportunity of getting another Rotel RB-1080 at a steal.
Although I already own a 1080.
Is it possible to do a mono block amplification with the 1080?
thanks,
Post edited by Tomasito on
  • Tomasito
    Tomasito Posts: 142
    edited May 2010
    I think the correct term will be bi-amplification of the rotel 1080
    F1nut Posts: 51,920
    edited May 2010
    The correct term is bridged as in being able to use each amp as a mono block. You can look on the back of your amp or in your owner's manual to see if it can be done. Keep in mind that bridged amps run very hot, are usually rated not to drive less than an 8 ohm load and tend to produce more signal noise.
  • Tomasito
    Tomasito Posts: 142
    edited May 2010
    Ok I'll read the manual of the 1080?
  • Tomasito
    Tomasito Posts: 142
    edited May 2010
    I checked the rotel website. Tough luck, the 1080 is not bridgeable, only 1070 is.
    The guy is selling the 1080 at such a good price, I'll probably get it as a spare.
    F1nut Posts: 51,920
    edited May 2010
    Hang on, do your speakers have dual binding posts? If so, you could bi-amp. That is run one amp to the low circuit L & R and run the other to the high circuit L & R. Be sure to remove the jumpers first.
  • Tomasito
    Tomasito Posts: 142
    edited May 2010
    Yes, I have an LSI9.
    where do I get an input signal to the second amp?
    F1nut Posts: 51,920
    edited May 2010
    You will need to use a "Y" splitter coming out of your pre amp unless your pre amp has two sets of outputs. You run the Right channel signal to both amps and the same for the Left channel. From the low amp, you run your Left and Right speaker cables to the respective low posts on the speakers. From the high amp, you run your Left and Right speaker cables to the respective high posts. Since both amps are identical, you don't have to worry about gain issues.
  • Tomasito
    Tomasito Posts: 142
    edited May 2010
    Will there be a sonic improvement?
    F1nut Posts: 51,920
    edited May 2010
    Tomasito wrote: »
    That's always the question, isn't it!?! If you try it, let us know what you think.
  • Tomasito
    Tomasito Posts: 142
    edited May 2010
    I will purchase the second 1080 tomorrow, and I will post my comments
