Mounting RTi38s to the top of speaker stands?
Turbota
Turbota Posts: 255
edited November 2003 in Speakers
I want to mount a set of RTi38s on top of a pair of 36" Wood Technology speaker stands. I ordered the optional larger wood mount-plates with the stands so they would cover the complete bottom side of the speakers when I set the speaker on top of the stand.
My question is: What do I use to hold the speaker to the wood mount-plate on the top of the speaker stand? I really hate to run screws into the bottom of these speakers, and I don't want to just place the speakers on top of the stands ... Someone may knock the speaker off of the stand if they bump up against them.
Thanks,
Ron
2-Channel Audio
Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
Onkyo ... M-282 . ... Power Amps .(Pair)
Onkyo ... C-7030 . _.CD Player
Polk . . *. RTi A7 - ....Front Speakers
Polk . . *. RTi A3 - ....Rear Speakers
Post edited by Turbota on
  • TheMaster
    TheMaster Posts: 184
    Rubber Stoppers(clear or black) are available at home depot or any of your local hardware store. They are very inexpensive (around $3.00). I hate leaving steaker marks on my speakers so, I stuck them on the stand and it worked fine.
    HT:
    DENON AVR-3803
    DENON DVM-1805
    SONY DVP-NS300
    SONY 36' HDTV Wega
    ADCOM GFA-555
    ADCOM GFA-555
    ADCOM GFA-2535
    ADCOM ACE-515
    POLK RTi70's (Bi-Amped)
    POLK CSi40
    POLK FXi30's
    POLK RTi38's
    POLK CSi20
    POLK PSW 450
    SVS PB2 Plus
    2 CH Stereo:
    AudioSource Pre/Amp 1
    Hafler DH-500
    Sony CDP-CX235
    Monster Cable HTS3500
    SDA SRS 2.3tl
  • andrewe77
    andrewe77 Posts: 17
    I think that the 38's on 36" stands is going to be way too top heavy! Even if they don't fall off the stands, if someone bumps them, the speaker + stand will come crashing to the floor.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Blu-Tack
    The best option for speaker to stand coupling.
    Agreed, I wouldn't have 38's on a stand taller than 24". And even at that height, they better be sand/shot fillable.
    Cheers,
    Russ
  • Turbota
    Turbota Posts: 255
    Thanks for the info. Blu-Tack it is ...
    I am a little concerned about the 38s on these stands, but they seem to be pretty stable. The Wood Technology stands have a fairly large bottom base plate.
    Do you think Blu-Tack would be avail at Home Depot?
    Ron,
    _________________________________________
    2-Channel Audio
  • Tour2ma
    Tour2ma Posts: 10,177
    office depot, wal-mart... it's more of an office supply item...
    it's commonly used to tack flip chart pages to walls.
    More later,
    Tour...
    Vox Copuli
  • Turbota
    Turbota Posts: 255
    Thanks Tour ...
    2-Channel Audio
