Sound Deadener
zingo
zingo Posts: 11,258
edited May 2010 in Wanted (WTB) Classifieds
I'm cheap. I have $15 in my paypal account and need some sound deadener for a speaker build, preferably in sheet form. Can you help me?
Post edited by zingo on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2010
    Polyfill or a Mattress pad from Wal-Mart. You can get loose Polyfill in bags, or sheets in the crafts department.
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Thanks for the suggestion, but I need the Dynamat type to deaden my drivers. :)
    Toolfan66 Posts: 18,066
    edited May 2010
    zingo wrote: »
    I bet I have some chunks left over in my closet. What speakers do you have?
  • HB27
    HB27 Posts: 1,518
    edited May 2010
    Go to your local auto body repair and they'll probably give you a couple of good squares from panel replacements. It's where I get mine.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited May 2010
    I think you can get a 2"x 2" square of Dynamat for $15.00~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    edited May 2010
    TNRabbit wrote: »
    If your paying that I will sell you 2" X 2" square for $5 LOL;)
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Klipsch Forte
  • Face
    Face Posts: 14,340
    edited May 2010
    What are you deadening, the horns or the cabinet?
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Horns, woofers, and passive radiators; I think that will be enough.
  • HB27
    HB27 Posts: 1,518
    edited May 2010
    Passives should be left alone.
  • Face
    Face Posts: 14,340
    edited May 2010
    I believe he's referring to the frame of the drivers only. Jake, they're stamped, correct?
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Yes, stamped basket with thin spokes. The baskets look almost identical to the Polk ones.
  • HB27
    HB27 Posts: 1,518
    edited May 2010
    IF possible leave the passive in and access it from the front to do the sound deadening. The passives are not available, frames warp easily, and there's sharp edges from the stamping that can/will cut into the surround.
    Inspect them closely .
  • zingo
    zingo Posts: 11,258
    edited May 2010
    HB27 wrote: »
    Thanks for the advice.
    edited May 2010
    How much do you think you need? as I know nothing about your speakers but would love to hear them. I will dig around tomorrow and see what I have. Make sure you PM me tomorrow so I don't forget about you.. If I have what you need I will mail it out to you "no charge" does that work for you???
  • zingo
    zingo Posts: 11,258
    edited May 2010
    PM will be sent tomorrow. :)
  • zingo
    zingo Posts: 11,258
    edited May 2010
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Bump. Anyone else have any extra dynamat type material laying around?
  • headrott
    headrott Posts: 5,496
    edited May 2010
    How much do you need. I have a some left over, but need some to do my 2B's. I probably have about 2/3 of an 18" X 32" sheet left, but the 2B's won't take much I don't think.
    Greg
  • zingo
    zingo Posts: 11,258
    edited May 2010
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited May 2010
    zingo wrote: »
    I bought some Fatmat on eBay for about 20 shipped. Put it all over the backs of my bookcases' thin backing boards. I actually may have a piece left.
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
