Receiver set up help
Great info here for this new member. I have on the way a pair of 70' a 505, and a C2 to pair up with my Yamaha 663 receiver and Mirage Nano Sat rears. My room is 14X26 and we sit 12-14ft from a 60" Sony LCOS. Should I set the Yamaha receiver to large or small speaker and any starting point suggestions on how to set up the 505 up crossover etc.? FWIW,The receiver has the (YPAO) auto sound adjustment system. Thanks much and I can't wait till this stuff gets here to replace my old very inexpensive Polk set up.
Post edited by inazsully on
Congrats on the purchase...lots of good people here.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Congrats and welcome to CP!
Experimentation is the key here, but personally I would start off trying the main speakers set to large and then try your crossover between 80-120. The problem is that your center channel should be able to handle some bass but not your rears so you will have to decide which compromise you prefer, a slightly thinner sounding center or rears with a little more bass than they can handle. Either way will sound very good I think, but just a heads up.
Peace,
PaulLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I would recommend setting the speakers to small and the crossover to 80hz. Then run the calibration and go from there.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
I'm probably looking at 80% TV watching, 15% standard DVD watching, and 5% Blu-ray watching. My thinking is that even though most all HD broadcasts are in 5.1 it seems that most studios don't spend a great deal of money on producing rear channel sound effects so with that in mind do you think perhaps going large in the 70's and crossover around 100? Any opinions will be welcome. Thanks and thanks for the welcome.
I would definitely give that a try. I would also try 80 as the crossover and see if that improves center channel clarify and presence.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I will try that first. Here's another perhaps stupid idea but the receiver is set up for using as a 7.1 system which I've never considered before and Ive heard that it's not worth it if you're watching all 5.1 material. How do you think the system would sound with a pair of Bose 901's (no EQ) for the rears and the Mirage nano sats for the sides? This would take a fair bit of time and effort so I'm just wondering if it's a waste of time.
I personally wouldn't bother with it, but I have never set up 7.1 so I am not much help. Especially for tv viewing it doesn't seem worth it to me since none of it will be in 7.1, only a select few (but increasing number) of blu ray discs. FWIW, I don't think that matching is as much of a problem with surrounds (others disagree) so if you feel like putting in the extra work and experimenting I would be interested in hearing about the results.
PEace,
I'll give it a shot just to see what happens. My problem is that I now have more speakers than I know what to do with. I also have a pair of Bose 101's that I replaced as rears with the Mirage Nano sats. Maybe I 'll sell my 901's and 101's and the current Polk towers and center channel and JBL subwoofer. I'll report back in a couple of weeks when I receive all the new Polk speakers. Thanks again.
