Recomendations for height speakers in 9.2 system
First the back round.
I have all rti speakers
9s
csi6
FXi6s
I was thinking either a3s or another pair of FXi6s.
Any recomendations?
9s
csi6
FXi6s
Any recomendations?
Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's
>Sub = MK Audio 10'
-PS3
-Directv
Post edited by Rocco1 on
What 9.2 are you running? Are you using height channels? As for rears you can get away with 2-3 above ear level. I have mine roughly 4 feet above but tilted down on the listening postion and manually adjusted with a SPL meter. 9 channels should be rather intense. Hope your listening area is big enough to support such a setup. My room is 14x22 and I feel sometimes even a 5.2 arrangement would have been enough. YMMV.
As for speakers I would run FXi series speakers as the side surrounds and a direct firing speaker in the back. As for your height channels again a nice bookshelf should do the trick, RTi6s come to mind.Shoot the jumper.....................BALLIN.............!!!!!
Go with fxi 3 or 5
if i were you i would use center channels, they have a much wider dispersion then bookshelfs.
