upgrade rti 12
hc_416
hc_416 Posts: 30
edited May 2010 in DIY, Mods & Tweaks
I own a pair of rti 12's and i have a problem with the bright ness and a little lack of bass, I was just wondering is there any way to up grade the interals like you did to the LSi sereis or am I carzy.
Post edited by hc_416 on
  • ohskigod
    ohskigod Posts: 6,505
    edited May 2010
    Xcapri actually asks a very good question. the RTi series can come off as a little bright to some ears, but if you're lacking bass, I'm going to go out on a limb and say you need beefier amplification well before any mods to the speaker.
    those 12's can suck down some juice
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • hc_416
    hc_416 Posts: 30
    edited May 2010
    i have a sunfie cinema grand sig. arch. choice 2 425*5 in 8 ohms and 850*5 in 4 ohms. i am running a yahama vx2500 as the pre. with the level on the fronts -2.0db's and the eq has the highs -2.0-0.0 form 20k to 500hz. I have 12 gauge speaker wire running from the current taps to the highs and votlage to the lows. I was just asking to see if there were any mod's because i see that the x-overs don't look to be the best.
  • jrgoswick
    jrgoswick Posts: 159
    edited May 2010
    Going out on a limb here, change your taps around-voltage to highs, current to lows(did I read that right).
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • Face
    Face Posts: 14,340
    edited May 2010
    Have you experimented with speaker placement?
  • dubradio
    dubradio Posts: 181
    edited May 2010
    hc_416,
    Just a few "just to make sure questions".
    1. Did you use Ypao auto setup from the receiver?
    2. Are you using any separate subwoofers?
    3. As Face had mentioned have you experimented with room placement?
    4. How about the terminals you have the wire run into at the speaker (top, bottom, or Bi-wire)?
    nooshinjohn Posts: 25,990
    edited May 2010
    That sunfire has more than enough to make the RTi's sing to the heavens. If speaker placement does not resolve things, I would suggest replacing the Yamaha with a dedicated preamp. I would also suggest bi-wiring using the current source taps to the highs and the voltage taps for the lows.
