2B standoffs
sda2mike
sda2mike Posts: 3,131
edited May 2010 in Vintage Speakers
i'm wondering if these are the ones....anybody ahve any clues..
http://www.microcenter.com/single_product_results.phtml?product_id=0218465
Post edited by sda2mike on
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited May 2010
    They look pretty darn close. If you replace all of them I would think you have a winner.
    F1nut Posts: 51,783
    edited May 2010
    They do not appear to be the proper size. You need to measure your originals first.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    sda2mike wrote: »
    Why not just use brass standoffs? And you'll want to double-check clearances... solder tends to add at least a millimeter to PCB height and on motherboards power pins will usually add several millimeters.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
