2B standoffs
sda2mike
i'm wondering if these are the ones....anybody ahve any clues..
http://www.microcenter.com/single_product_results.phtml?product_id=0218465
Post edited by sda2mike on
They look pretty darn close. If you replace all of them I would think you have a winner.
They do not appear to be the proper size. You need to measure your originals first.Political Correctness'.........defined
President of Club Polk -
Why not just use brass standoffs? And you'll want to double-check clearances... solder tends to add at least a millimeter to PCB height and on motherboards power pins will usually add several millimeters.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter
