Interconnect question
vmaxer
vmaxer Posts: 5,121
edited May 2010 in 2 Channel Audio
I am thinking about upgrading the interconnect cables from my processor (Sunfire TGP-5) to my amp (Sunfire Signature 405X5) on the front 2 channels only at this time. This is just to upgrade the "2 channel" portion of my dual purpose system. I listen more and more to 2-channel from SACD's and vinyl..
The question is should I use XLR or RCA connections??? I am currently using very cheap XLR's from Monoprice (I think that's where I got them) I am also using a Y cable/splitter so I can bi-amp the front speakers - 1.2TL's.
I plan to stay with the bi-amp, so whatever I go with will have to include plans for this.
All input is welcomed..
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    Opinions???
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    heiney9 Posts: 25,498
    edited May 2010
    Upgrade cables; if you like balanced then look for balanced cables, and using a "Y" adapter to bi-amp is doing nothing, nada, not a thing but adding another item in the signal path. Ditch the Y adapters.
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    heiney9 wrote: »
    H9,
    Thanks, but how does one bi-amp correctly??? I'm not saying balanced is best, I don't know. That is part of the question.
    Which is best, XLR or RCA, how does one correctly bi-amp?? The signal has to go to 2 places, one for highs and one for lows:confused:
    If I am going to invest in better cables, I want to get the best bang for my bucks:o
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited May 2010
    vmaxer wrote: »
    H9,
    Bi-amping is just as it states..............using (2) amps; many prefer a "sweeter" amp on the highs and "solid iron fisted" amp on the lows. All you are doing w/a Y-splitter is splitting the same single signal into two parts, no difference whatsoever. In fact you may even be degrading the signal by using the Y-adapters. You are actually doing a slightly bastardized form of bi-wiring, but it's not completely that either.
    As far as which is best XLR (balanced) or RCA (single ended).............that's a hot topic and it has been discussed hundreds of times on CP (search). For me personally in my set up with a single ended class A amp I actually prefer the singled ended RCA's to balanced XLR's.
    Let the vigorous discussion begin about which is "better" :)
    edited May 2010
    Where are you using the Y-adapters? I assumed at the speaker outputs........but then I thought how would you wire that.
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    heiney9 wrote: »
    H9,
    Thanks again, I appreciate your help. But I still need to know how does one take the front right output from the processor/preamp and send it to 2 amps without a splitter???:o:confused::o I have only one output per channel on the processor and it needs to go to 2 places:confused:(same would apply to the left output)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    heiney9 wrote: »
    The output on my preamp/processor is split into two cables, One goes to the amp for highs and one goes to the amp for lows.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited May 2010
    Wow, I am confused :confused:.
    Bi-amping takes a single signal from a pre-amp (many higher end pre-amps have two sets of outputs) (1) set of outputs goes to amp #1 and then is hooked to the top terminals on your speakers. (1) set of outputs goes to amp #2 and then is hooked to the low terminals on your speakers.
    How are you inputting (2) signals into your amp to get a single output? Unless it's a multi-channel amp. If you don;t have (2) separate outputs on your pre-amp then yes many would suggest a Y-adaptor at the output of your pre-amp.
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    heiney9 wrote: »
    I am probably doing a poor job of describing the connections:o Here is what I am doing...
    Front right XLR output from Sunfire TGP5 into a Y splitter (also XLR). One lead from the splitter going to channel one of Sunfire Signature 405X5 amp and the speaker output from that amp channel going to the right 1.2TL tweeters. (no jumper on speakers) The other lead from the splitter going to channel 2 on the amp and the speaker output from that is going to the lows on the 1.2TL.
    Does this help any??
    Thanks for your help!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    Unless you are going to use and external crossover between the preamp and the amps to separate the highs and the lows, then you have no choice than to use a 'Y' connector on each channel. When I biamp'd my 1.2TLs, used a 'Y' connector that Frank from Signal cable custom made for me to split the signal to my Parasound (highs) and my Adcoms (low) and it did a fantastic job.
    If you have a 1.2TL manual it goes into great detail as to how to use the various methods to biamp.
    Billy if you need a copy of the manual, email me and I'll send you the pdf of the manual.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited May 2010
    You can go RCA from the TG to the amp, then go RCA from the second inputon that channel to the next channel. It's all in the manual. No need to use Y-splitter. Incidentally, unless you're having a noise issue with RCA, I found with the Sunfire equipment there's not much difference between XLR and RCA.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    Thanks a lot, I already have one. ( I think you may have been the one to send it to me).. As far as XLR or RCA what do you think?? I am considering PNF Audio XLR interconnects and Y cables. Any thoughs?? I want to do this only once,,,
    Can't afford to keep trying, this is why I want to learn from others experience.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited May 2010
    vmaxer wrote: »
    IMHO, if you are not having any noise issues with the single ended RCAs, i.e., dead black presentation then I would just stick with them.
    I heard an all balanced system at Ted's house during his Polk Fest and it was dead quiet, then again all the gear was BAT at the time and all you could use was XLRs.
  • TNRabbit
    edited May 2010
    vmaxer wrote: »
    Check up one post.
    TNRabbit
    Sunfire TG-IV
    edited May 2010
    Great info Joe, but totally irrelevant because as far as I can tell he's using a single amp.
    I am still totally confused? To Vmaxer; so does each XLR (you only have 2) carry a stereo signal..........if not, I'm not getting how you can only use a single XLR for the "right" and a single XLR for the "left" and then split it to go into the amp.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited May 2010
    Looks like he is using a couple of multi-channel amps?
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
    edited May 2010
    Hawkeye wrote: »
    Gordon
    That may be the case. I'm a 2 channel guy and when people start talking 2 channel I automatically assume a 2 channel amp. I'm sure someone else will chime in and help. I just can't picture it, but I'm not familiar with the gear he is using either and if it's a multi channel set-up I'd have to see a diagram.
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    Hawkeye wrote: »
    Gordon
    Atleast one according to his first post.
    vmaxer wrote: »
    ... my amp (Sunfire Signature 405X5) ...
  • TNRabbit
    edited May 2010
    heiney9 wrote: »
    See post #12; that is the amp the OP is using. Read the thread!
    TNRabbit
    Sunfire TG-IV
    edited May 2010
    TNRabbit wrote: »
    Read the thread!
    Why, it's not my set-up? If your post helps the OP, then great, problem solved. Now all he has to do is decide on brand/type of cables. :)
  • TNRabbit
    edited May 2010
    heiney9 wrote: »
    You said you'd need to see a diagram; there was one in post #12, that's why I said read the thread~ :rolleyes:
    :p
    TNRabbit
    Sunfire TG-IV
    edited May 2010
    TNRabbit wrote: »
    :p
    Ah, well I finally looked closer at it. I assumed your diagram was a suggestion, not the way the OP had it hooked up, since it wasn't the OP providing the diagram. :p;)
    Atleast we're getting somewhere now :)
  • ChrisA
    ChrisA Posts: 3
    edited May 2010
    vmaxer wrote: »
    Those monoprice XLR cables are low cost but not "cheap".
    I'd go so far as to say that "cheap" XLR beats $250" RCA cables every time. The reason is that the expensive RCA cable try to minimize problem that balanced connects just don't have. Not only does the XLR connector use a balanced signal, which is pretty much immune to common mode noise, it sends it at a higher level (more volts) So it's not just the physical wire that is different but the signal itself.
    Well, that's the ideas, now it could be your equipment "fakes it" and sends consummer level, single ended signals over XLR. In that case most of the advantage of using XLR goes away. But you still do have the advantag of the much more robust and reliable physical connectors, theRCA connectors themselves are not a great design. Almost every other connectors is better, BNC, XLR, 1/4" phono and so on. So even in the case where your equipment "fakes it" I'd go with XLR if you can
    edited May 2010
    You can do a WHOLE lot better than mono-price cables, very easily.
    Single ended RCA's are most excellent so no worries there. You may notice a difference if you run a truly balanced system in which ALL components are truly balanced input to output. XLR connections are most times better served for very long runs where signals can degrade over a long distance.
    I'm not saying in every situation one or the other is better, but as I stated in my own personal system I prefer a very nice high end single ended RCA to the XLR's.
    P.s. There are certain specific designs of amps that favor a truly balanced I/C, like BAT an Pass Labs "X" series of amps. Those are designed to run balanced and actually have slightly better numbers when run that way. But, those are the exceptions not the rule. XLR's typically do have better noise rejection but not always for shorter runs which are typical of most hi-fi component users
    edited May 2010
    ChrisA wrote: »
    Nope and Nope.
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    vmaxer wrote: »
    heiney9 wrote: »
    Sorry guys, had to leave for a while...
    For the 2 channel I am using a 5 channel amp which has 405 watts each. The description above is for the front right speaker only (2 XLR cables and one splitter) The left is set up the same way.
    Thus, I am using 1 channel for the left highs, 1 channel for the left lows, 1 channel for the right highs and 1 channel for the right lows all at 405 watts each.
    I also have another 5 channel 200 watts per for the surround speakers. This systerm serves as both home theater and 2 channel. I am using it more and more for 2 channel thus the desire to upgrade the cables for that portion.
    My signature list most of the remaining equipment.
    It seems as though there may be some merit in using the XLR cables, it also seems that I may benefit from a active crossover that has XLR ins and outs.
    Thoughts?????
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    ChrisA wrote: »
    I am not saying the cables aren't any good, I just thought maybe I could upgrade and get some benefit from it. I do know that cables can make a difference.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited May 2010
    heiney9 wrote: »
    Wow did I miss something here? I thought he was talking about using a "sweet" sounding amp on top and a ballsey amp on the bottom.:confused::confused::confused:
    EDIT: I just read post #27 and am no longer confused.:D
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    When I got the Sunfiire 405 x5 the manual recommended this type of hookup. It did "seem" to help the overall clarity, especially at higher volumes:cool:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2010
    what are you guys talking about, he just needs to use some coat hangers, they are so much better than Balanced cables which are just silly anyways... ;)
    jk, and would recommend if you are trying to bi amp getting an external crossover to do so, at least to me this would be the best for sound quality and allow you to control the top end and the low end and make sure your sending a different signal to the bass drivers and a different one to the tweeters.
