Removing Polyswitches
Driver_King
Long story short, I removed my Poly-switches and my tweeters don't work. When I put the top Poly-switch back in, the tweeters kick back on. Why is this?
Home Theater:
Onkyo TX-SR805
Behringer EP2500 for SDA's
Polk SDA II fronts
Polk Monitor 5Jr. surrounds
Polk Monitor 4 back surrounds
DIY A7-900 and DIY A3-300
Onkyo TX-SR805
Polk SDA II fronts
Post edited by Driver_King on
Did you use jumper wire in place of the ps's ? If not you need to complete the circuit.Speakers: SDA-1C (most all the goodies)
That would be the problem then.:o Do I need to use a jumper wire for both of the crossovers on the speakers? Also, would it be okay to cut off the wires off of the Poly-switches to finish the circuit?Home Theater:
Onkyo TX-SR805
Polk SDA II fronts
DIY A7-900 and DIY A3-300 -
I recommend replacing the polyswitches with an .5 ohm 12 watt Mills resistor to maintain the proper resistance designed into the circuit otherwise you may find the tweeters have too much energy.Political Correctness'.........defined
President of Club Polk -
I just wanted to say thanks to all of you who've helped me with my SDA's. There isn't anything like having a question answered within minutes of posting.:cool: For now, I think I'm going to stick with the jumpers. I can already tell the difference.:)Home Theater:
Onkyo TX-SR805
Polk SDA II fronts
If you find them a bit bright take F1s recommedation on the resister. Thats what I did.Speakers: SDA-1C (most all the goodies)
and,, do you have the replacement tweeters?JC approves....he told me so. (F-1 nut)
I don't have the replacements. I guess I'm one of those few who enjoy the SL2000's.:eek: They are a bit bright but they are tamable. Audyssey does a great job at smoothing out their ~12khz peak and makes them very enjoyable.Home Theater:
Onkyo TX-SR805
Polk SDA II fronts
George may be saying, do you have replacement tweeters in case you get crazy on the volume without the polyswitches for protection.Speakers: SDA-1C (most all the goodies)
After this post Jesse, I will be getting some .5 ohm mills and do this. The highs in my 3.1TLs are a tad harsh, but not too bad at all. The best reason to do this is to keep a proper balance for the tweets. How much are the highs reduced by the .5 ohm resistor? I would think not by much seeing as they such low resistance values, but how noticable is it to your ears? Thanks again Jesse for the great advice.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
re: How much are the highs reduced by the .5 ohm resistor?
I can only speak for the 2.3TL. Depending on the crossover, it might be pretty similar for other models. For the 2.3TL it's right at 1dB (comparing a .5 ohm resistor vs a jumper, replacing the polysw).
1dB is the minimum that most people but not all people can detect. -
Greg
Greg, just so you know your 3.1TL's did not come with a polyswitch. That said, there is no reason that you couldn't add a .5 ohm resistor to tame the tweeter energy a little.
How noticeable? Enough for my ears to tell the difference.
"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
That's right, I was confusing my 3.1TL's and 2B's. I forgot that the 3.1TL's didn't have a poly. Thanks again Jesse. Hmmm, if that's the case then the 3.1TL's were not designed with the intent of using a poly. Really, the highs don't need to be tamed very much at all. Would it over-do it then adding a .5 ohm resistor to tame the tweets? I know this gets into a persons preferences, but........any help would be appreciated.
Greg
Try it, you may like it.
Not to hijack the thread but I sometimes find my 1C's a little on the bright side.
I am going to check to see if the polyswitches are still in, would it be a problem if I put in a 1 ohm resistor?ProJect Perspective II Turntable & Benz Micro Ace
ProJect Tube Box II & Philips/Amperex tubes
Luxman L-430 Integrated
Polk SDA 1C's -
You can put a 1 ohm resistor in there no problem.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
why a 1 ohm instead of a .5 ohm?JC approves....he told me so. (F-1 nut)
A 1 ohm resistor is really going to kill the high frequencies, try a .5 ohm instead.Political Correctness'.........defined
I replaced the polyswitches in my 1C's with a .5 ohm 12 watt Mills resistor,IIRCJC approves....he told me so. (F-1 nut)
