Monster M1.4 Bi-wire hook up
acdds
I hate to sound like a schmuck but how do you hook these things up? Both ends have 4 connectors (Red & Black- High pass + Red & Black-Low pass). My homemade biwires had 4 connectors on the speaker end but only 2 (red&black) on the receiver side. Is there some type of adapter that I need to reduce the 4 connectors on the receiver side down to a single red and a single black connector? I greatly appreciate any advice!
Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's
Post edited by acdds on
Just twist the high and low + together on the amp side and the same for the - . Then put the seperate connections on the speaker side.
Best of luck
DanRecever AVR 8000
Amp PA 4000
CDR 26
Mains RTI 150 Bi wired
Center CSI 40 Bi wired
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
Both sides have 4 soldered banana plugs on them already. So what I was wondering is there a way to hook up the amp side without reterminating the existing banana clips?Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's -
I see not sure if there is an adapter for that. I'm sure someone on here can tell you if there is.
DanRecever AVR 8000
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
the person before you must have had a bi-wire capable amp. I am assuming the banana plugs aren't stackable? (You can't plug one into the other?) If they are not then I really can't think of a way to do that effectively, I would reterminate 1 set with a stackable banana plug and then plug the existing banana plugs into that.
good luck.
p.s., I happen to have a bi-wire capable amp, so you are welcome to solve your problem by sending them to me
What about cutting all 4 banana plugs off of one end. Then connecting both reds and both blacks and terminating it with 1 red and 1 black monster quick lock bananas. Do I need to solder them or will the screw attachment (with a little heat shrink on the end) do the job?Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's -
I would thing the connector would be good enough. It was recomended to me that I DO NOT solder the ends together (amp side) on my AudioQuest biwires.
Hope this helps
DanRecever AVR 8000
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
That is not true M1.4 bi-wire. M1.4 has 4 ends on one side and two on the other. It has screw on connectors, spade or banana, which you have to buy separately.
What you have sounds like standard 14-4 bi-wire cable, which Monster also makes.
In that case, yes - you can connect +to+ and -to- at the amp end and use a QD banana. You don't need to solder.
At the other end, just use four bananas.
Doc"What we do in life echoes in eternity"
SVS -
I just checked the ebay web page that the auction was on. The seller wrote that these were custom made for him a couple of years ago. I am also looking at the wire at it has "M series . M1.4s . Multiple Bandwith Precision Wound Speaker Cable by MONSTER CABLE . US Patent # 4,734,544 . 1ft." written about every other foot on the cable. My guess is that he had them custom terminated. Oh well, I missed that part and I gues I will just have to reterminate them! Thanks for everyones help!Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's
