Do Tubes take the edge off of Digital???
wayne3burk
wayne3burk Posts: 939
edited May 2010 in Electronics
I've seen a couple of high end SACD / CD players that are have tubes.
So I guess my question is , is - do tubes take the square edges of of Digital Music?
If you run your CD into a tube pre + then to a tube amplifer does that equals = smoothing out the 1s and 0s of CD's, Flacs, etc.?
Just a wondering if that's the idea behind having a tube output stage of a SACD / CD and if you're using a tube pre and power amp if you get essentially the same result.
thanks,
wayne
Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
Post edited by wayne3burk on
  • punk-roc
    punk-roc Posts: 1,150
    edited May 2010
    To echo what BlueFox is saying... While I don't know for sure for all components; the integrated preamp I have has tubes but only utilizes the tube section for analog and has SS amps for the digital.
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • wayne3burk
    edited May 2010
    hmmm....
    my hypothetical is a regular CD going into the tape input of a tube preamp > then a tube power amp.
    So does that effectively round off the 1s a 0s a bit...
    wayne
    F1nut Posts: 52,000
    edited May 2010
    That makes no sense.
  • John K.
    John K. Posts: 822
    edited May 2010
    Wayne, the basic premise of your question lacks factual support. There's no inherent "edge" , square or otherwise, involved in digital sampling. Any material can have an edgy sound if the original performance was like that, or the recording process, whether analog or digital, was poorly done and introduced that coloration. Digital sampling, as long as there are at least two samples of the analog waveform taken(which happens when the sampling rate is at least twice the frequency of the sound sample)reproduces the analog waveform exactly after the DAC conversion, and we hear the same analog waveform coming out as went in before the digital sampling took place. This is simply(although not simple)mathematics: when at least two sample points are present to be mathematically analysed, only one possible waveform fits those points. No naive "connect-the-dots" type of analysis takes place where the more points there are, the closer the reproduction is.
    A fairly brief explanation(including mathematical proofs which can be skimmed over)is found in these materials which have previously been cited here, which Dr. Lesurf originally prepared as introductory material for his students in electronics and physics. To quote the bottom line, the summary is that "You should also know that the amount of information in a continuous analog signal can be specified by a finite number of values. This result is summarised by the Sampling Theorem which states that we can collect all the information in a signal by a sampling rate 2B, where B is the signal bandwidth. Given this information we can, therefore, reconstruct the actual shape of the continuous signal at any instant 'in between' the sampled instants. It should also be clear that this reconstruction is not a guess but a true reconstruction".
    This is basic technology which was proved mathematically by Nyquist and others about 80 years ago and which has since been used in practice in industrial, military and scientific fields where it's a little more crucial than in audio that what comes out of the digital sampling is precisely what went in.
  • dkg999
    dkg999 Posts: 5,647
    edited May 2010
    The answer to the OP's question is yes.
    DKG999
  • headrott
    headrott Posts: 5,496
    edited May 2010
    John K. wrote: »
    If, what you say is accurate then why does a D/A converted signal sound different to me than a purely analog signal (assuming it is the same master recorded source)?
    Greg
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited May 2010
    Not sure, but are we talking a hybrid integrated amp, where the pre- section is tube, and the output stages are SS ?
    Or are we talking power amp with the tubes driving the output at low levels in Class A, then switching to SS Class AB at high output ?
    On a positive note, I'm confused at a much higher level now. :)
  • headrott
    edited May 2010
    BlueFox wrote: »
    You do realize don't you that a lot of recording has been digital for years, and it is converted to analog for the LP.
    Yes, I do. Luckily most of the music I listen to was recorded prior to digital tape decks and hard drive recorders though (i.e. pre-1980's). That would be about 90% of the music I listen to.
    Greg
