Do Tubes take the edge off of Digital???
wayne3burk
I've seen a couple of high end SACD / CD players that are have tubes.
So I guess my question is , is - do tubes take the square edges of of Digital Music?
If you run your CD into a tube pre + then to a tube amplifer does that equals = smoothing out the 1s and 0s of CD's, Flacs, etc.?
Just a wondering if that's the idea behind having a tube output stage of a SACD / CD and if you're using a tube pre and power amp if you get essentially the same result.
thanks,
wayne
thanks,
wayne
Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
Post edited by wayne3burk on
To echo what BlueFox is saying... While I don't know for sure for all components; the integrated preamp I have has tubes but only utilizes the tube section for analog and has SS amps for the digital.
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
hmmm....
my hypothetical is a regular CD going into the tape input of a tube preamp > then a tube power amp.
So does that effectively round off the 1s a 0s a bit...
wayneYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
That makes no sense.Political Correctness'.........defined
President of Club Polk -
Wayne, the basic premise of your question lacks factual support. There's no inherent "edge" , square or otherwise, involved in digital sampling. Any material can have an edgy sound if the original performance was like that, or the recording process, whether analog or digital, was poorly done and introduced that coloration. Digital sampling, as long as there are at least two samples of the analog waveform taken(which happens when the sampling rate is at least twice the frequency of the sound sample)reproduces the analog waveform exactly after the DAC conversion, and we hear the same analog waveform coming out as went in before the digital sampling took place. This is simply(although not simple)mathematics: when at least two sample points are present to be mathematically analysed, only one possible waveform fits those points. No naive "connect-the-dots" type of analysis takes place where the more points there are, the closer the reproduction is.
A fairly brief explanation(including mathematical proofs which can be skimmed over)is found in these materials which have previously been cited here, which Dr. Lesurf originally prepared as introductory material for his students in electronics and physics. To quote the bottom line, the summary is that "You should also know that the amount of information in a continuous analog signal can be specified by a finite number of values. This result is summarised by the Sampling Theorem which states that we can collect all the information in a signal by a sampling rate 2B, where B is the signal bandwidth. Given this information we can, therefore, reconstruct the actual shape of the continuous signal at any instant 'in between' the sampled instants. It should also be clear that this reconstruction is not a guess but a true reconstruction".
This is basic technology which was proved mathematically by Nyquist and others about 80 years ago and which has since been used in practice in industrial, military and scientific fields where it's a little more crucial than in audio that what comes out of the digital sampling is precisely what went in. -
The answer to the OP's question is yes.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
If, what you say is accurate then why does a D/A converted signal sound different to me than a purely analog signal (assuming it is the same master recorded source)?
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Not sure, but are we talking a hybrid integrated amp, where the pre- section is tube, and the output stages are SS ?
Or are we talking power amp with the tubes driving the output at low levels in Class A, then switching to SS Class AB at high output ?
On a positive note, I'm confused at a much higher level now.
Sal Palooza -
You do realize don't you that a lot of recording has been digital for years, and it is converted to analog for the LP.
Yes, I do. Luckily most of the music I listen to was recorded prior to digital tape decks and hard drive recorders though (i.e. pre-1980's). That would be about 90% of the music I listen to.
Greg
