Bad mastering?
ctrulock
ctrulock Posts: 73
edited May 2010 in Speakers
I was listening to a "greatest hits" cd of Journey and towards the end of the 1st song my sub woofer starts booming like I was listening to a competition bass cd.
I have my sub crossed over at 55 hz and plays smooth down to 30ish hz. Think this is a case of bad mastering of low bass? No other songs on the whole cd did this.
Do some studios not even listen to bass below like 40 hz and don't notice there is info below 40 hz that is out of level?
Post edited by ctrulock on
  • Litz
    Litz Posts: 111
    edited May 2010
    Well the booming could be bad mastering, but likely an overabundance of 40-80hz. Below 40hz is more rumble than boom.
    Your assumption is true in many cases though. Some remastering is done with mini monitors or those that sharply cut off at 50hz. If there is no bass, or too much bass below that...some folks miss it completely.
  • ctrulock
    ctrulock Posts: 73
    edited May 2010
    Yeah when I used the term "booming" it was not meant in the sound quality sence. I meant there was significant low bass sound probably should have used the term "my sub started producing low bass that was out of place" instead of booming.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2010
    I wouldn't put much stock in the sound of many 'greatest hits' rock cd's.
  • Litz
    Litz Posts: 111
    edited May 2010
    A good "bad" example: Van Halen OU812 has such terrible mastering, bass below 80hz was pretty much non existant.
  • RuSsMaN
    edited May 2010
    That's Van Hagar, NOT Van Halen. That album doesn't count.
  • Litz
    Litz Posts: 111
    edited May 2010
    RuSsMaN wrote: »
    Maybe they could remaster with Dave's vocals...and more bass...
