Good Polk's for Rotel
JDOGG
JDOGG Posts: 433
edited November 2003 in Speakers
What floorstanding polk speakers would be a good match for a Rotel RMB-1075?$700 limit.
Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable
Post edited by JDOGG on
    F1nut Posts: 51,673
    SDA 2B or 1C's..maybe some 3.1TL's if you can find them.
  • 4_everyman
    4_everyman Posts: 50
    The RMB-1075 is a fine amplifier. I'm using one myself. If you're keeping it below $700, i'd recommend either the RTi8 @ $700 or the RTi70 @ $600. Those are Crutchfield's prices.
    Rgds,
    --pete
  • JDOGG
    JDOGG Posts: 433
    are there websites that sell polks lower than crutchfield?(RTi8's or 70's) Do i need a 5 channel amp or could I get away with just a two channel Rotel. Any model. And then use the reciever to power the center and surrounds.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • mantis
    mantis Posts: 17,313
    I would suggest the Lsi9'.If you can swing alittle more,the Lsi15's are the bang for the buck.
    Dan
    Dan
