Just bought a turntable -
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    "Phono" cables from the TT to the PS audio pre(it's an interference/shielding thing)I like the VPI phono cables in mine,,you can find them on A'gon reasonably priced,but they go fast,,I'm currently lookin for some Van den Hul "first ultimate" ,,BTW,,the PS Audio pre that you picked has been quite the rave and,according to the experts?(grain of salt),,has quite a nice upgrade/mod path.Seems as though you've assembled a very nice vinyl front end,,enjoy. :)
    Thanks George!! I hope you are keeping an eye on Jerry:D
    I got the PS Audio pre for half price so I thought I would try it. Just for kicks I installed it with the old Onkyo turntable with a 20 year old Audio Technica PM7000 MM phono catridge and couldn't believe the difference it made. :cool:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    vmaxer wrote: »
    How are the options in the PS Audio pre set up for gain control i.e., straps, dip switches, trim pots etc.?
  • thsmith
    thsmith Posts: 6,082
    edited May 2010
    I think it has a button for MM or MC, no straps or switches. I could be wrong though.
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    Here is the manual for it, if you want photos of it let me know. Additionally, here is a link to a short video that shows all the adjustment features including what can be controlled via the remote.
    http://www.youtube.com/watch?v=TGfpCj3rkVQ
    Thanks for your help!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    lost the manula somehow???
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited May 2010
    vmaxer wrote: »
    Ah Haaaaaa! Very clever design! Not only do they have preset gain control switching in the rear of the unit, they have a "variable gain" control vs an attenuator on the front that you can adjust manually or remotely. Very, clever design if you aske me. I would imagine that with a very low output MC cartridge set to the lower gain selections in the rear, being able to adjut the gain manually bit-by-bit you will reduce the possibility of hiss. I really like that, very cool.
    Nice very, very nice Bro.:)
  • hearingimpared
    edited May 2010
    vmaxer wrote: »
    Hahaha ya big goof how'd you manage to loose the manula or manual in English:D so soon?:eek::D
    I scanned through the pdf manual, this is a very well thought out piece of gear.:)
