Amp stands
woodsman10b
woodsman10b Posts: 408
edited May 2010 in 2 Channel Audio
Thought someone here would problably be interested in these-
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170477733408
They look very nice. :D
Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
Post edited by woodsman10b on
  • chandler9a
    chandler9a Posts: 878
    edited April 2010
    Looks really nice!
  • Cpyder
    Cpyder Posts: 514
    edited April 2010
    Looks pretty sweet. What does it accomplish besides looking cool?
  • thuffman03
    thuffman03 Posts: 1,325
    edited April 2010
    Cpyder wrote: »
    Amps can be very heavy and large. Some Audio racks don't have the space or weight limit to allow such big amps.
    Plus it allows for more air movement around the amps to keep them cool.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Nice! I like Mapleshade Records amp stands too.
    http://shop.mapleshadestore.com/departments.asp?dept=46
    Taint cheap though.
  • Cpyder
    Cpyder Posts: 514
    edited April 2010
    thuffman03 wrote: »
    Air movement is a good thing!
  • hearingimpared
    edited April 2010
    So is vibration isolation!:D
  • schnottus
    schnottus Posts: 15
    edited May 2010
    Am I the only one who finds this claim a little ridiculous? "Surprisingly, maple platforms are much warmer, clearer, punchier and more detailed than granite, slate, glass (the worst), myrtle or exotic hardwoods"
  • pearsall001
    pearsall001 Posts: 5,244
    edited May 2010
    Cpyder wrote: »
    About the same as uber expensive cables. But they sure do look purdy.
  • hearingimpared
    edited May 2010
    schnottus wrote: »
    Yep!, but probably not the only one. It all about the resonace properites of the material.
    Think about the wood compostion of a Stradivarius violin and why it sounds so good compared to other violins made of different woods. Often copied, never comes close.
  • hearingimpared
    edited May 2010
    This from a guy who lays out mucho $$$ for high end cables!:eek::D:p
  • pearsall001
    edited May 2010
    Ah, Joe...those days are long gone. All the uber stuff has been sold & now I'm strictly using quality cables that have a great performance/form/function & cost ratio. The uber costing cables did not live up to their price point as far as I was concerned.
  • hearingimpared
    edited May 2010
    You never did post up a review or impressions of the MITs you bought or if you did I missed it.
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2010
    unless you don't have a rack that can support the weight of them. Like I wouldn't want to stick a Krell mono block 600 series into a VTI rack as I don't think it would support them all that well. That and ventilation, class A amp into a tight enclosed space= not a good idea.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2010
    I could hear a difference between Bluestone blocks under my speakers vs Maple.
    YMMV>
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • hearingimpared
    edited May 2010
    cstmar01 wrote: »
    I don't know Chris. I have my MF Tri-Vista setting on the third tier of my four tier VTI stand and it supports it effortlessly and is open on all sides so my amp only becomes warn to the touch after playing for hours and there are only a few inches of space above the amp so it is suprising that it only get warm. Filling all the posts and cross beams with lead shot may lend to the strength of the rack.
  • cstmar01
    edited May 2010
    see IDK how tough they are. I just am weary of setting a lot of weight on MDF as I know it can take it but there's always a giving point. Guess they are stronger than I thought, which is good seeing thats the rack I plan on getting and keeping for a long long time.
  • ESavinon
    ESavinon Posts: 3,067
    edited May 2010
    My Krell monoblocks have their own custom made stands made by Sound Anchors :cool:.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited May 2010
    ESavinon wrote: »
    I want krell monoblocks ......
  • ESavinon
    edited May 2010
    I sold a kidney and half my liver to get those.:D
  • cstmar01
    edited May 2010
    ESavinon wrote: »
    tell me where I can sell it and I'll do it!
  • zingo
    zingo Posts: 11,258
    edited May 2010
    My goal next year is to make an audio rack using the Flexy Table style, but making the shelves out of sandwiches of carbon fiber and Dynamat. Should make a strong yet deadening platform.
  • hearingimpared
    edited May 2010
    cstmar01 wrote: »
    Actually Chris the crossbeams design of the VTI under the MDF are what causes it to have no give. As I said I would imagine the lead shot gives more strength to the crossbeams and veritcal pillars.
  • cstmar01
    edited May 2010
    ahhhh, see I didn't know it had the cross beam at all. I thought it was just a rectangle and the MDF sat on top with nothing for support underneath (I've never seen the bottom of it). Thanks for the info!
  • hearingimpared
    edited May 2010
    zingo wrote: »
    That sounds very interesting! Let us know how you make out. BTW I considered using Dyamat to line the under side of my VTI MDF platforms but I would have to break each tier down and with the weight of the lead shot in each tier. . . well . . . I'm just to lazy to try it.:eek: for now at least.:o
  • zingo
    zingo Posts: 11,258
    edited May 2010
    I can't see any fatal flaw in the project as long as I make the carbon fiber thick/strong enough to hold the weight of an amp. It should be a good combination of self dampening, light weight, and just plain cool.
  • hearingimpared
    edited May 2010
    cstmar01 wrote: »
    The crossbeans are in a triangular shape. It supports the whole platform with two of these triangular crossbeams for each MDF platform. Actually I believe it is composit of MDF and another material but don't hold me to that.
